Results 1 to 8 of 8
Thread: Can iG be installed from external HDD?
    was Boston -> now Canada!
    Searched for a bit and couldn't find my answer. Does anyone know if iG can be installed from an external HDD?
    I do not have a DVD drive in on my CarPC and in order for me to set it up I would have to remove my passenger seat and remove my PC in order to attached an IDE DVD drive. COnsidering that we got 6 inches of snow here today and it's pretty cold I was hoping to do it the lazyman's way and just connect my external HDD with the setup files on it from the DVD. This way I can stay within the confines of my warm vehicle
    I tried to install it but it keeps asking to insert disk one after I generate the map files. Not sure if there is an ini file I can modify in order for it to install from whatever source the setup files are on.
    Thanks,
    Chuck
    Jun 2005
    Michigan
    You need to make a disc image (.iso) and mount it with a virtual drive program like Daemon Tools. I did this with iG3 and it worked great. Only problem for me was sending the giant iso over 802.11b....
    MII-12000 / Ampie / Lilliput 7" / BU-355 / PicoPSU / uSDC
    Currently: Enjoying the setup, but always contemplating my next move...
    Thanks for the reply. I've never used Daemon tool but have read a lot about it in my passing. I'll give that a try and see how I make out.
    Chuck
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    You can copy the disks 1,2,3 to your hard drive and install it from there. It will find the disks and will install.
    Maximum Bitrate fixerofallthing's Avatar
    May 2005
    Lawrenceville GA
    Quote Originally Posted by MGD View Post
    Must be in the root of C: to work correctly for map creation.
    The Car 2005 Scion xB
    The Truck 2004 GMC Canyon
    Apr 2006
    I installed IG by just copying the files from my test computer as I was in the same situation as you. If you copy the iNav folder from your Program Files, that is all the program files. If you copy the iNav iGuidance folder from the Windows folder, that contains the maps. I zipped both folders and was able to put them on a thumb drive and on my carputer in about 5 minutes. Fully functional.
    Quote Originally Posted by fixerofallthing View Post
    Basically just copy the raw DVD file structure to the root of C:? The setup file will be in the root and disks will be subdirectories in root?
    Quote Originally Posted by 1Munkey View Post
    You just did a raw copy of these directories from your test machine over to your car PC and this worked? You obviously had a previous version though right; so the support files from the old version worked with the new? Interesting. I may try this method first but I have reservations about all the necessary files getting properly updated.
    Thanks,
    Chuck
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    Just install everything (program and map) on your test machine as like you will do it on your carPC. Once done, zip the entile installation folder (that include program and maps) and transfer it to your carPC. Normally, maps data is intall in C:\iNav\Maps (or similar), and not with the main program (C:\Program Files\iNav\iGuidance). I just manually move the Maps folder into iGuidance folder so that everything is inside iGuidance folder.
    Now zip iGuidance folder to your Ext HD and extract it in the same folder structure in your CarPC. It will works, and no previous installation require.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
  1. Installing XP with external CDROM
    By Ricky327 in forum Software & Software Development
    Last Post: 06-17-2008, 06:03 AM
  2. Newbie HDD Idea (moved from FAQ Emporium)
    By madmartigan in forum General Hardware Discussion
    Last Post: 08-27-2006, 07:38 PM
  3. External Apps Missing In action
    By blk02si in forum Road Runner
    Last Post: 05-04-2006, 04:13 PM
  4. External USB HDD Disappears After Reboot
    By tbird2340 in forum General MP3Car Discussion
    Last Post: 03-11-2006, 10:07 AM
  5. Problem with ITPS / hibernation and External USB HD
    By veetid in forum Power Supplies
    Last Post: 01-02-2006, 09:35 PM
