Results 1 to 6 of 6
Thread: gps antenna
    Dec 2005
    gps antenna
    Is possible connect the gps antenna to autoradio car antenna?
    Elsewhere
    No.
    How about the Wiki?
    FLAC sama's Avatar
    Feb 2006
    London, UK
    ... because radio uses a much lower frequency than GPS. GPS works at 1575.42MHz while FM works from 88-108MHz (AM is lower).
    The best FM antennas are a big T shape, and GPS are a circular polarised type.
    hope that explains it somewhat.
    Dec 2005
    So noway to avoid to put out my car the gps receiver instead of connect it to the car by some way...
    Elsewhere
    If you want GPS in your ride, you have to have a GPS receiver/antenna of some sort.
    Does that mean you need a bulky device on the roof of your car? Not necessarily. There are other alternatives.
    How about the Wiki?
    FLAC sama's Avatar
    Feb 2006
    London, UK
    I haev my GPS receiver placed in the corner of the dashboar, inside the car where it's barely visible. It gets good coverage. Of course though, for the best signal, you want it on the roof where it can see a maximum amount of sky. ANY other position (including on top of the boot) does not get as much coverage. But like I said, mine works fine where it is.
  1. FS: Garmin GPS 15L with Holux Antenna
    By wi77iam in forum Classified Archive
    Last Post: 10-05-2006, 06:50 PM
  2. OEM GPS Antenna
    By unixxx in forum GPS
    Last Post: 06-05-2006, 11:54 AM
  3. No GPS Signal from antenna on E46
    By dreamstriker in forum GPS
    Last Post: 09-16-2005, 10:45 AM
  4. Replies: 11
    Last Post: 12-06-2004, 04:48 PM
  5. Gps Module + External Antenna + Waas + Usb
    By e_z_street in forum GPS
    Last Post: 10-06-2004, 04:57 PM
