Results 1 to 10 of 19
Thread: Tyco A1029A/B Update...
    Maximum Bitrate LiquidKernel's Avatar
    Feb 2005
    I got a hold of Tyco and had them send me data sheets with sample schematics for the A1029A/B and A1030. Very straight forward setup, a cheap gyro (the one they recommend by Analog Devices is $40) just a pair of optocouplers for the odometer and reverse light signal.
    They gave me the name of a company that retails them. The price lists the A1029A for $38 @ 100 units and the A1029B for aroudn $60 @ 50 units. I am going to see how much sample units cost.
    My goal for the whole project is $100. I have tons of parts at home (including opto's, RS232 low-level converters), etc... so I just need the gyro and GPS receiver (and antenna).
    This looks promising! I am sure many of you are in dire need of DR, just as much as I am.
    Feb 2005
    Called the supplier again, they will call me back within a few days about the pricing for low quantity orders.
    Will let you guys know.
    Feb 2005
    Got a price quote of $299.15 for 5 units, that's $59 per unit!
    The price is for the A1029B, which includes a PCB with header and antenna connector. This is literally a quarter the price of the Ublox module.
    Now to see if I should shell out the $300 and start development... if anyone would want to get the remainig 4 from me, I'd like that
    Feb 2005
    Ordered a single sample from the supplier. The Tyco A1029B is going to be here in a few days. BOOYAH. Time to start working.
    Jan 2007
    Liquid,
    How were you able to get ahold of Tyco?! I've been trying with no luck to find the datasheets on these things... been getting transferred around all over the place... do you think you could hook me up?
    Feb 2005
    They have many suppliers. If you contact their GPS devision (http://www.tycoelectronics.com/gps/), they will help find the closest one to you. From that link you can ask Tyco about datasheets, etc.
    htl
    htl is offline
    Jun 2005
    Boston, MA
    liquid,
    did you order a sample unit from www.rell.com? how were you able to order less than the minimum of 16?
    or did you order 5? if you have any units left over, i'd like to purchase one from you.
    Feb 2005
    Quote Originally Posted by htl View Post
    liquid,
    I was able to purchas a quantity below 16 by special request. Doubt they do it often. Guess I got lucky with the people I talked to. Waiting on a Mouser order for the rest of my parts.
    Jan 2007
    Liquid.... I PM'ed you re: datasheets... do you think you could email them to me?
    htl
    htl is offline
    Jun 2005
    Boston, MA
    i compared the specs for the tyco A1029 and ublox TIM-LR dead reckoning gps modules and found a few differences:
    the tyco A1029 does not come with internal SRAM that can be backed up with a backup battery. from my understanding, the backup battery on the A1029 only maintains the RTC and i believe that the position information is not stored for next use if the power is cut off from the module. however, if a command is sent before power is cut off, the position data will be stored in the on-board flash memory and will be available when power is restored. this may be a little difficult to manage since the com port may be tied up by other programs before a carpc goes into hibernate mode. i'm going by the assumption that power to the gps module will be lost when the car is shut off. if power is maintained, this will be a no issue.
    the ublox contains internal SRAM that is backed up with a battery when power is lost. there is no need to send any commands to the module in regard to position data.
    an alternative is to go with tyco's A1030 module which is programmable and contains the SRAM memory that is battery-backed. this seems to be a more comparable module to the ublox. i'm not sure what pricing info is for this module.
    another difference is that the ublox tracks up to 16 satellites whereas the tyco tracks up to only 12. this isn't a big factor since 4 satellites are sufficient for gps positioning.
    price is also another big difference... after contacting a retailer for the tyco A1029B, they changed their pricing as follows: 1-15 units @ $132/unit, 16-127 units @ $47.87/unit, and the price break continues for higher quantities (no more minimums). ublox is still sitting at $199.
    i'm leaning towards a ublox at this point...
    can anyone shed any more light on my findings?
  1. Chuck's Skins lots of pics Update 7-16-07
    By Chuck in forum RR Released Skins
    Last Post: 11-10-2011, 08:22 PM
  2. 95 Lexus SC300 - 0l33l's "Project SC300"
    By 0l33l in forum Worklogs
    Last Post: 01-14-2010, 08:55 AM
  3. FrontRow 1.01 update runs smoother on ibook
    By churnopol in forum MacCar
    Last Post: 11-26-2005, 12:33 PM
  4. XM update song
    By rjoek in forum Road Runner
    Last Post: 08-06-2005, 02:01 AM
  5. GPS Update fequency and Dead Reckoning
    By Scouse Monkey in forum GPS
    Last Post: 05-12-2005, 06:46 AM
