Results 1 to 4 of 4
Thread: Trying to decide between two OE style recievers.
    Aug 2005
    Orange County, NY
    I've searched before asking this, I promise.
    Anyway, I'm looking for an OEM style GPS reciever, and narrowed it down between the PMB-288 and the GM-M308, both available from Deluo. I haven't really heard anything about the Gm-M308, which uses an EverMore chipset. The PMB-288 uses the Sony CXD2951GA-4 chipset, which I've heard isn't the best, but it is WAAS enabled. From what I've read on here, I gather I'm better off using a SirfstarIII based reciever, but I haven't been able to find one in an OEM style.
    So anyway, if I can't find a SirfIII based OE reciever, which of the two do you think I'd be better off with? In case it makes a difference, I plan on using this with iGuidance 3.0.
    _
    Mar 2004
    Little Elm, Texas
    http://www.sparkfun.com/commerce/cat...php?cPath=4_86
    I'm using this board: http://www.sparkfun.com/commerce/pro...roducts_id=780
    Here's the thread I started about it: ET301 Eval board
    And you have probably already read this thread, but just incase: OEM GPS Installs
    Jan Bennett
    Registered User
    May 2003
    Quote Originally Posted by JoeKamel View Post
    Most OEM module are old, uses crappy chipset, needs TTL<>RS232 converter and are expensive.
    You are better off buying a complete SIRF3 GPS. Open it and what do you find, a nice little module with all the bits you need. Plug in an external active antenna to complete it. Much cheaper and better than those crappy OEM module you will ever find.
    If you do ever find a nice up to date OEM module I doubt they come cheap.
    ET301 Eval board
    Plenty of cheap GPS receiver out there with SIRF3 or RFMD chipset, mine is BT, reason is that I also want to be able to connect my PDA/phone GPS navigation to it.
    Aug 2005
    Orange County, NY
    Arg, the more I read, the more I realize that doing most of my getting lost in NYC makes GPS a royal pain hehe. I think I'm going to have to wait for jcdillin to slap together a couple more of his ublox DR modules. Thanks for the info though guys.
  1. 3" ebay arcade style trackball...
    By 3onDubs in forum Input Devices
    Last Post: 10-24-2005, 08:11 PM
  2. WTB: Lilliput A/V Cable NEW style!
    By djtrickee in forum Classified Archive
    Last Post: 06-22-2005, 09:19 PM
  3. Replies: 3
    Last Post: 05-13-2005, 09:03 PM
  4. WTB: Old Style Xenarc Cable
    By Danceheaven in forum Classified Archive
    Last Post: 04-28-2005, 06:14 PM
  5. Comparisons of Recievers
    By PaCMaYNE in forum GPS
    Last Post: 11-24-2004, 12:28 PM
