Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: Friendfinder software?
  1. #11
    Constant Bitrate TheLandYacht's Avatar
    Oct 2005
    Austin, TX
    Sprint has this service where you can keep track of your "child" through their GPS enabled phone...checkable either on YOUR phone or through a web interface...I wonder if that is relevant to this thread...and if it could be polled at regular intervals to give a track.
  2. #12
    FLAC sama's Avatar
    Feb 2006
    London, UK
    NewBend might help in tracking.
    Tracking a moving object is easy, but navigating to it is another problem all together! You can't use current navigation techniques as they all assume a fixed destination.
    One approach is to aim at an area around the target, and navigate there, and decrease the size of the area the closer you get to it. I've not seen any navigation s/w that does this.
  3. #13
    Maximum Bitrate wi77iam's Avatar
    Jun 2003
    Chester Springs, PA
    The newest version of GPSGate has this capability.
  4. #14
    One Sharp Cheddar ThunderStick's Avatar
    Aug 2006
    West Allis, WI
    Quote Originally Posted by wi77iam View Post
    Kick *** find... If only mobile internet wasnt so damn expensive
    New Age Garmin - Skin for RR
  5. #15
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by sama View Post
    Just need to be able to change destination on the fly.
    Shouldn't be to hard to adapt FreeDrive to do this. There would have to be a minimum amount of time between re routes though.
  6. #16
    Dec 2006
    If its just about two buddies tracking each other for a trip or whatever reason you could easily working around a internet server connection. Just connect directly the two phones via old school dial up. would probably give you real time update rates (1hz) without lag.
  7. #17
    FLAC sama's Avatar
    Feb 2006
    London, UK
    I guess you could, but it wouldn't be a minimum time, it would be by distance, getting quicker as you approach the target.
  8. #18
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    No, what I mean is because of the time it would take to recalculate a route, you would have to be careful not to ask it to recalculate too often otherwise the time between recalculation requests might be less than the time it takes to recalculate. Obviously the nearer you are to the object the quicker it will calculate.
    I still think it is do able, would just need to add some extra SDK commands to freedrive.
  1. Which software
    By ponch37300 in forum Software & Software Development
    Last Post: 01-09-2007, 05:53 PM
  2. New system - What software do you all use... what should I put on mine?
    By dsj1979 in forum Software & Software Development
    Last Post: 11-19-2006, 04:16 PM
  3. AutoTap used to develop custom software!
    By Dodger1417 in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 09-25-2006, 11:51 AM
  4. MSDXM.OCX - Why oh why don't you fix that NOW?!
    By Zippy1970 in forum Media Engine
    Last Post: 02-28-2005, 05:36 PM
  5. My numpad controlled custom MP3Car software - need your opinions
    By PorscheMP3 in forum Software & Software Development
    Last Post: 04-11-2002, 11:30 AM
