I just got and installed the same package, DeLorme Street Atlas 2007 bundled with the Earthmate LT-20
GPS receiver. It wanted 800x600 or better to install, but once it was on there it runs fine on 640x480. In fact the buttons are much more usable at lower resolution, otherwise they're TINY. I just installed it yesterday and had a couple of hours to try it out. I'm very happy; maybe because I've never used any other GPS nav
software before.
I'll agree that the interface is cluttered at first. But you can remove toolbars and minimize menus and side-panes until all you have is one row of menu options up top, one row at the bottom and the panning controls on the right. See below. I haven't relied on it for directions yet, just tested around home. It has a "High Contrast," color scheme that is great for night driving or driving in general. Here's a picture at 640x480:
I've cleaned up the interface even more since then; the left pane is totally gone and the bottom menus are minimized so you see only the tabs (Map Files, Print, Draw, GPS, Route, etc) Also, the turn-by-turn directions it speaks out loud are detailed. It tells you to turn on a particular road name, tells you the distance and estimated time, and re-routes if you go off the path. It did already screw up once during
testing though; it told me to make a left on an overpass instead of telling me to get on a ramp.
