Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: Streets and Trips 2007 toolbars dissapearing
  1. #11
    FLAC Marvin Hlavac's Avatar
    May 2005
    I wouldn't count on it either, but it would be nice.
  2. #12
    Dec 2006
    Quote Originally Posted by Marvin Hlavac View Post
    While this feature could be easily implemented, I don't have the right to remove a safety warning from someone else's product.
    You aren't removing it - you are automatically acknowledging it on our behalf, after we configure your program to do that. In all honesty, I think that would be safer than causing an extra look at the screen.
    If you don't want to do it, could you hint at how - for someone who is less of a programmer than you?
    BTW, yes, putting the shortcut to KEYS in Roadrunner does indeed start S&T within RR with the default settings defined in Keys. Now if I can just get RR to pass F5 to your program to do those changes as well! I haven't been our driving with my setup yet, it will be interesting to see if your auto-reroute will work when S&T is inbedded in RR.
    Kevin
  3. #13
    May 2005
    I should install RR to see if I could modify S&T Keys (and AR Keys) to be compatible with RR. But I'm working on a couple of other projects that will keep me busy for at least a couple of weeks. Perhaps then I will explore this idea.
    The auto-reroute feature in S&T Keys requires that MS Streets & Trips 2007 (or MS AutoRoute 2007) be in full-screen navigation mode (but this requirement could be removed). This feature is screen resolution dependent. It only works for pre-set screen sizes. So far it has been enabled for the following resolutions: 800 x 600, 1024 x 768, 1280 x 600, 1280 x 768, 1280 x 800, 1280 x 1024, and 1680 x 1050 (that's various laptop screens). I suspect the automatic re-routing feature will not work as is in RR.
  4. #14
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    In RR, you can use Sendkey to send any keyboard shotcut to any program you like.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
  5. #15
    May 2005
    So it should be easy then. If you like any of the code in S&T Keys, then just copy & paste it (modify if needed) to RR.
  1. Brushed Metal Streets and Trips 2006 skin
    By Mattkins99 in forum Road Runner
    Last Post: 11-08-2008, 12:21 AM
  2. Streets & Trips 2007 not taking Sendkeys
    By HyperSprite in forum Road Runner
    Last Post: 11-19-2006, 07:25 PM
  3. Streets & Trips 2007
    By LostAngel in forum GPS
    Last Post: 11-03-2006, 05:03 PM
  4. Replies: 6
    Last Post: 11-02-2006, 10:13 PM
  5. Replies: 6
    Last Post: 06-02-2006, 10:20 AM
