Anyone see Iguidance that far off before? If i'm approaching an intersection (regardless of speed) by the time i get to the other side of the intersection Iguidance just then displaying me entering. I have the puck mounted on the rear deck of my car, but don't think that would make that much difference.
Yeah, that limo is about 100 ft long!![]()
It does that with me too, they say GPS lags about 1 second behind you so you do pass the intersection before the GPS can catch-up.
If you use it for what it's designed for *Guidance* instead of following you around, you probably won't miss a turn tho'
I got mine mounted in the front above the rear view mirror and it always seems pretty bang on. I get the beep right before I meet the intersection. It does tell me I'm offroad when I'm parking in my garage though![]()
I believe that when commerical GPS first became available, a purposeful discrepancy was engineered into them as it comes to distances. The reason was that they could not be converted into a "weapons grade" gps by the various number of bad guys.
I do not know if any of the current GPS systems still have that discrepancies build into them.
This "might" be for the reason you are seeing distances not being reported correctly.
Try this.... Put a piece of metal under the GPS, allowing the GPS's magnet to stick to it. I had the same problem and I NEVER had a problem after this.
The point of the metal under the GPS receiver is to provide it a ground plane to help amplify the signal. It's better if the metal is connected to the car's chassis to ground it.
I just got my BU-353 with SiRF III today to replace my GM-210 with SiRF II. And, yep, on iGuidance, it's completely off! I drive past an intersection, 3 seconds later my little arrow finally cruise by the same intersection. I even put it on my roof (so it has the ground plane) and it has 7-10 out of 12 sat's. My old GM-210 can barely get 5 sats on the roof, but it's dead on. I haven't found a solution as I just got home from work, but just thought I'd chime in.
Gen 1: Pentium 3 1GHz - ATX - 2005
Gen 2: Pentium M 1.6GHz - ITX - 2006
Gen 3: Pentium M 2.0GHz - 5.25" SBC - 2007
Gen 4: (coming soon: Core2 Duo - 3.5" SBC - 2009)
...it never ends
Just to add another point, comparing the GM-210 with the BU-353, the reported elevation is different by 30-100 feet (i.e. BU-353 said I was at ~140 feet, GM-210 said I was at 40 feet. I was right on the beach, and I can see the water, and it could NOT have been 140 feet below me. Even with tide and whatnot, the difference is remarkable. I'll do a drive this weekend with my laptop and the carpc to run both GPS receivers at the same time. I hope to put up some pictures to examine the difference in reported position and elevations.
...it never ends
Great! Please do report your findings..subscribing.
