Page 1 of 3 123 LastLast
Results 1 to 10 of 28
Thread: BU-353 Problem
    Newbie lucky1's Avatar
    Aug 2006
    Chicago
    Unhappy BU-353 Problem
    Thanks for all help in advance.
    I have the BU-353 receiver, and I cannot get it connected, I think that it is because I don't have the VCP, I have loaded the included drivers from the disk that came with it, that didn't work, went to the web site downloaded that driver that didn't work either.
    I think that when I go to the device manager I should see, prolific serial to USB comm port. I am not seeing this. also when I pug the receiver into the USB slot, windows XP does not say found new device, maybe that is the problem, or do I just need a new receiver.
    Lucky 1
    Elsewhere
    Are all the USB ports enabled in the BIOS?
    Yes, you should see Prolific USB-to-Serial in the device manager.
    How about the Wiki?
    Aug 2004
    Im having a similar issue. But mine is related to cold weather. It seems with the recent cold weather my BU-353 wont be detected by iGuidance. So what i did was take it inside the house when i get out the car and in the morning plug it back up and fire the PC up and sure enough iGuidance detects it. Maybe this could be your issue. Has it worked before? Also if so, do you see a pattern or is it just sporadic
    Hope this helps
    Aug 2006
    Chicago
    ok
    But I don't think thats the problem, my garge is not that cold inside and it doesnt work there either.
    Thanks anyway
    Sep 2006
    turkey ankara
    does other usb devices work ? and did you try to install the mouse to any other pc to be sure if it is working or not?
    Variable Bitrate john05srt4's Avatar
    Oct 2006
    Florida
    Same problem. Just installed it new from box yesterday. Worked great.
    Got in car later turned PC on and it doesnt detect it at all?
    tried other usb ports, nothing, tried to reinstall drivers, nothing?
    im trying to use streets and trips 06 or the OEM gps config CD. Neither detect it.
    and no its not cold.. 75 degress and hasnt gotten wet?
    10 acura TL tech
    10 BMW S1000RR
    Jun 2006
    I'm having the same issue with the BU-353. Other USB devices work on the same port, but the receiver isn't detected when connected. Any ideas?
    May 2007
    im having a similar problem maybe, one time it wasnt detected so i had to re-install the software, but now it doesnt even get a signal, maybe its because i moved it to under my passenger seat... could that be to low or too much blockage?
    Oct 2006
    Florida
    i sent mine back as defective..it worked fro 5 minutes moved it to another usb and dead on 3 different PC's.
    new one has been working great and moved it with no problems.
    10 acura TL tech
    10 BMW S1000RR
    Mar 2006
    Montreal
    if you don't set the BU-353 at 9600 baud you WILL NOT get any output and it will not work at all until you set it at 9600 baud, in port properties and in GPS application software...
  1. Lilliput TouchKit problem solved!
    By AAVfReaK in forum LCD/Display
    Last Post: 11-07-2010, 09:29 AM
  2. reconnected puter and now audio problem..
    By NYCdesignkid in forum Car Audio
    Last Post: 05-31-2006, 12:09 AM
  3. gps navilock and com problem
    By lele67 in forum GPS
    Last Post: 04-01-2006, 08:41 PM
  4. Problem with directshow filter and WMP
    By EricE in forum Software & Software Development
    Last Post: 03-01-2006, 11:38 AM
  5. Car Idle - power/amp problem?
    By TheFaze in forum Car Audio
    Last Post: 12-16-2005, 12:10 AM
