Results 1 to 8 of 8
Thread: Destinator and adding address
    Newbie stasik-a4's Avatar
    Aug 2003
    australia
    Hi guys.....
    Ok what i want to know is when im trying to add address to favourites why isnt my onscreen keyboard work to add a name to the address? ie (johns home) why do i have to use my normal keyboard to type in the name???
    Does any one know a fix for it? or what it might be?
    Maximum Bitrate jonessc's Avatar
    Nov 2006
    Wales, UK
    hi,
    Assuming your using map monkey, there is a setting that is under 'environment' that says 'always show on screen keyboard' check that you havnt selected no in that box.
    Whether you have this setting or not, there should at least be an icon for a keyboard at the bottom of the menu that you will have to press for the keyboard to appear.
    Aug 2003
    australia
    onscreen Keyboard works fine with everything else but not when you want to add it to favourites and asighn a name to the address that you have just typed in and want to save it then you cant use onscreen keyboard thats there... you can only type in with normal keyboard....
    Nov 2006
    Wales, UK
    i see what you mean i have never tried adding a favourate manually, there is no button to bring the keyboard up.
    Must be something that can be done, the only other quick fix that i can think of is to use the windows inbuild on screen keyboard, i cant find any setting that wil display the in build destinator keyboard...
    sorry i cant be any help!
    Aug 2003
    australia
    Quote Originally Posted by jonessc View Post
    Thanks for help....
    Any one else got any ideas? or know how to get around it?
    Nov 2006
    Wales, UK
    Not much of a solution, but ive been trying freedrive, which is virtually identical to map monkey, and still based on destinator d3, you way want to try it, this doesnt appear to have this problem, as it has a decent on screen keyboard...
    heres the link:
    www.freedrive.co.uk
    you will need to register on the forums to be able to download anything, worth a try. I have map monkey installed as well, and they dont appear to intefere with each other, so you can switch back if you dont like , just change your rrconfig to the directory you install it to
    Feb 2007
    I just purchased a CapPc and was wondering if the on screen keyboard is a seperate software i will need to purchase or does it come wiht the touchscreen driver? can anyone please let me know. I would love to have this feature?
    Thanks in advance.
    Nov 2006
    Wales, UK
    Quote Originally Posted by hafizesh View Post
    Thanks in advance.
    It is a feature of your operating system/front end program you use...
    Windows XP has a built in on screen keyboard, try going to Start>Run>Type 'osk.exe' without the quotes, that will load it.
    Very rare youll need it if you use a decent front end, as they have one built in...
    CarPuter Progress:
    Planning:-----> [||||||||||] 100%
    Hardware Buying:-> [||||||||||] 100%
    Software:-----> [||||||||||] 100%
    Installing:-----> [||||||||||] 100%
    Current Project= Making skins in photoshop...
