Give us some more info and maybe we can make suggestions. Where is your antenna mounted? How many satellites are you tracking? How fast are you going? Is this gps WAAS capable and do you have it enabled? What mobo/cpu are you running? Normally, a gps position lags you're true position due to inaccuracy in the signal and time delay in the position processing and the speed of you car. GPS is only accurate to about 3 meters but may be 10 meters depending on number of satellites. The software updates at a one second rate, so when travelling at 60 mph, you can go 88 feet between updates. So with a poor signal, you could be up to 120 ft off with a perfectly good gps. 400 ft off seems to be excessive though.
LinkBack URL
About LinkBacks
