I figured out the full screen mode, i had to press alt and space bar, and choose "Maximize".. but it still goes into full screen mode when i restart the program.
Still have the question about the device warning.
Brett
Hi,
I have two questions about iGuidance v 3.0 UMPC:
1. I accidentally clicked one of the icons that made iguidance go in to "full screen" mode, and I can't get out of it!
2. Every time I start up iGuidance, i get the warning "Please make sure the GPS receiver is properly connected, even when it IS connected, and working! This warning is prohibiting me from focusing on the window from Road Runner - in order to focus i have to set the class to #32770, the class of that warning.
Any ideas?
Thank,
Brett
Brett
F is use to toggle full screen mode On/Off.
The other problem is you have to solve it out. Most likely because the COM port driver isn't available when iG starts. Also, iG has problem with COM port higher than 9. So if you use COM port 11, you have problem.
Y2K Accord Dell GX150
EmoRebellion is a SCAMMER
The device was not being recognized properly by the computer every time.. so I uninstalled it from device manager, reinstalled drivers, and let it install itself again. Works fine now.
Brett
