First one looks like a TNC, could be an RP-TNC. They are common antenna connectors on wifi access points. They have relatively low loss at microwave frequencies. THe second one I don't think I have seen before. Is that the antenna side of the GPS? THey could be using a proprietary connector for thier purpose. It also has the look of a TNC.
I would cut off the connector from the GPS wire (called coax) and solder on the proper connector for your eval board.
Michael
LinkBack URL
About LinkBacks
The second is my OEM GPS antenna... it's smaller than the first one, and it's not threaded, it's a "press-on" type. I realize the colored plastic connector around it isn't actually standard for the connector but rather added for ease of plugnplay. It's also right-angled, but I don't know if that makes a difference. So anyway I need to see what adapter I need to connect these two together. Looks like they're both female too. Thanks for your help on this!
