Results 1 to 10 of 10
Thread: Carputer will not boot up with GPS receiver connected
    Newbie Mick300ZX's Avatar
    Apr 2006
    New Jersey
    When the GPS receiver is connected the computer will not boot up, it will stay on the EPIA screen. If I plug the GPS receiver after the computer in on it will work normally. The receiver is a Holux USB GPS, carputer EPIA Mini ITX with Windows XP professional, Roadrunner with Simplistique.
    Mod with a purpose and enjoy the ride
    Mick300ZX.net
    Cardomain
    Calm
    Down
    Or
    Get
    A
    2
    Week
    Vacation
    -Love
    The
    Forum
    Policeman
    Wiredwrx's Avatar
    Jan 2003
    Quote Originally Posted by Mick300ZX View Post
    And your PS, HDs, other USB devices, is it a cold boot or hibernate or standby?
    Michael
    Apr 2006
    New Jersey
    PS= M1-ATX, HD = Ultra ATA/100 20G, other USB devices = External hardrive and touchtone screen.
    It's at cold boot.
    Mick300ZX.net
    Cardomain
    Calm
    Down
    Or
    Get
    A
    2
    Week
    Vacation
    -Love
    The
    Forum
    Policeman
    Wiredwrx's Avatar
    Jan 2003
    It's at cold boot.
    I think you are drawing too much power. Try removing some of the other components, and see if ti boots with the GPS connected. How is the external hardrive powered, through USB or some other way. Is the 20gig a 3.5 or 2.5 inch drive?
    Michael
    Aug 2006
    Central PA
    I had the same problem with my airclick. If I ran the device through any kind of usb hub it magically worked, if you have one around give that a try.
    Apr 2006
    New Jersey
    Quote Originally Posted by Wiredwrx View Post
    Michael
    The external hard-drive is powered through USB and it's 2.5.
    I'll try your suggestion and see what happens.
    Mick300ZX.net
    Cardomain
    Mar 2006
    Colorado, but Canadian!
    If you hav eenable USB devices checked in the BIOS, that allows a USB keyboard to roam around before the USB drivers are loaded by your OS. If your receiver is putting out crappy data, or something, the motherboard can hang up trying to figure it out.
    I second for trying it on a different port.
    The fact that it works normally in windows suggests a POST conflict.
    1.9in x 2.9in -- 47mm x 73mm
    Apr 2006
    New Jersey
    Disconnected the external hardrive and boot up normally with the GPS receiver connected. Looks like I'm drawing too much power for my PS.
    Will a M2-ATX be enough?
    Thanks guys.
    Mick300ZX.net
    Cardomain
    FLAC DodgeCummins's Avatar
    Oct 2000
    DFW area
    You need to supply power directly to the drive...not through the EPIA usb port.
    Like they said, a powered HUB might be your answer...power the hub directly off your power supply.
    Aug 2005
    Pennsylvania
    Yes, an m2-atx would suffice. Also, power your hard drive enclosure by drawing power directly from your power supply. But only after you get a higher wattage one.
  1. Replies: 42
    Last Post: 04-24-2006, 02:27 PM
  2. carputer hangs on windows boot screen
    By acura cl in forum General Hardware Discussion
    Last Post: 09-12-2005, 05:47 PM
  3. Replies: 11
    Last Post: 08-18-2005, 11:02 PM
  4. CoPilot Software or USB GPS Receiver package
    By Zip-Lock in forum Classified Archive
    Last Post: 05-13-2004, 08:30 AM
