Page 11 of 32 FirstFirst ... 23456789101112131415161718192021 ... LastLast
Results 101 to 110 of 320
Thread: Dashcam video with GPS speed imprint - court date soon...
  1. #101
    May 2008
    erkme73,
    Great explanation and now that I have that information it sounds like that would be the most accurate. Thanks for the info. I just need to figure out how to get the speed etc from the GlobalSat BT-359 to overlay while using SecuritySpy
  2. #102
    Variable Bitrate eric_barcus's Avatar
    Mar 2007
    subsrcibing to read at a further date
    very interesting stuff
  3. #103
    Constant Bitrate lacning74's Avatar
    Apr 2008
  4. #104
    Apr 2008
    Anyone found a nice stealth mini security camera that doesn't have glare problems like in thess videos?
    http://www.youtube.com/watch?v=0mAKYX15woo
    http://www.youtube.com/watch?v=ubpHZyyD6SY
  5. #105
    Jul 2006
    seattle
    Quote Originally Posted by lacning74 View Post
    Thanks for the inspiration!
    I hardwired the DVR and camera to an always on fuse via an Add-A-Circuit. I keep it set to motion-activation. It will also automatically turn on if you have it hardwired to an ignition only source. I'm not sure I want GPS speed imprinting for now.
    Did you mean the camera would continue recording when the ignition is on and motion only when ignition is off?
    How do you do that?
    Thanks to you guys for the inspiration.
    after almost blamed for an accident I bought the exact same dvr and an auto iris ccd camera.
  6. #106
    Apr 2008
    Quote Originally Posted by skuller View Post
    How do you do that?
    Sorry for the confusion. It can only have one setting. I have it wired to an always-on source. I just meant if you wanted it only on when the car is running, you can wire it to an ignition switched fuse since the unit automatically starts up when it receives power. If I did wire it to an ignition switched fuse, I would probably set the DVR to be continuous recording then.
  7. #107
    Jul 2006
    seattle
    I see.
    are you using 24 hour motion detection? or always on when ignition on?
    I am planning to have 24 hour motion detection but the main purpose of my setup is video taping any possible future accident (I hope none happen).
    How's the motion detection while driving? is it continuously recording or there's a few seconds gap every here and then?
    I haven't install mine since the camera is huge, about 12cm long w/ lens. I need to figure out how to mount it.
  8. #108
    Apr 2008
    I see.
    I have it on 24 hour motion detection. Pretty much no gap while driving except while stopped at a light if the intersection is not busy enough to keep the motion detector going. I have noticed a gap also while driving on a dark road for a while since there wasn't enough movement activity changes on the screen to keep it recording. You can lower the threshold sensitivity so it will pretty much stay on with any movement. You can also set how long it stays on after motion stops.
  9. #109
    Jul 2006
    seattle
    What kind of dc-dc regulator do you use?
    I am not sure which dc-dc regulator with high efficiency
    I have lm78xx regulator, but since it's a linear reg. it would waste too much energy and drain the battery.
    Also, how about engine cranking? With your dc-dc regulator, does it affect the camera and dvr?
  10. #110
    Mar 2005
    Quote Originally Posted by erkme73 View Post
    Court date was yesterday. Judge reduced citation from 72 to 68 based on the video evidence. Also withheld points. Probably the fairest of outcomes. In the end, my speed infraction went from 17 over to 13 over, and my insurance company won't know.
    On the down side, less than 24 hours after my court date, my wife was pulled over - doing 18 over. No dash-cam or GPS. It won't be here until next week
    I wish to heck I had a dash cam.
    I was driving with my wife, doing exactly the speed limit. Saw a cop pull into traffic behind me. Checked speedo and ensured I wasn't speeding. Continued along knowing cop was there. Then after a few lights (stop start) still checking speedo very carefully I come to stop at a red light, the cop flips his lights on and pulls me over.
    He did not use a Radar, lidar, anything. He simply saw me accelerate quickly from a light and then assumed I was speeding 10 over. I hadn't had a speeding ticket for about 5 years previous so I could do defensive driving, but I was innocent so it made me mad. Went to court and they offered deferred adjudication (but I pay fine and stuff still), but I was innocent. Went to court and basically proved IMO my innocence as the distance between the light that was green, and the light that was red where I stopped completely. Basically there wasn't enough distance to get up to the speed he said I was going and completely stopped in the length available. The cop actually told me I convinced him after the case (not that it matters). The judge reduced the fine to the same as defensive driving would have been, but like I said I was innocent (and it went on record) so it was annoying as hell to me.
    Furthermore the judge at the end of the case goes, "I'll call you on Monday with the results" so you don't even know the outcome at the end... I learned my lesson though, don't go to court if you are innocent, go if you are guilty and you need to get it reduced.
  1. Replies: 65
    Last Post: 10-13-2009, 06:51 PM
  2. Watching video while using GPS / web / whatever
    By lastberserker in forum General MP3Car Discussion
    Last Post: 04-19-2005, 02:11 AM
  3. Replies: 21
    Last Post: 02-10-2005, 11:39 PM
  4. Glitchy video when gps running. . . help!
    By PaPP in forum FrodoPlayer
    Last Post: 08-12-2004, 09:42 AM
  5. Mediacar V1.8.5
    By coyote in forum MediaCar
    Last Post: 02-16-2004, 01:16 PM
