Page 30 of 32 FirstFirst ... 20212223242526272829303132 LastLast
Results 291 to 300 of 320
Thread: Dashcam video with GPS speed imprint - court date soon...
  1. #291
    May 2009
    Quote Originally Posted by RipplingHurst View Post
    Just got this from a vendor (eTaroko), via Amazon for $135.00 (the main page shows what seems to be the same unit for $215). Unit arrived fast. You can also find something similar for $125 on ebay, but I'm not sure if it's the same unit.
    Here's some pictures:
    The unit:
    Attachment 62081
    The cheap Transcend 16GB class 10 SD card is not included of course.
    It seems that there are a bunch of similar such units, probably cheap copies of some original I have no idea what is. The unit is light and it's all plastic. Accepts 5V dc and comes with two page, two color basic configuration guide with pictures and a 17 page B&W manual.
    Its very very similar to what Ive just got
    http://www.amazon.com/SVAT-CVP800-Po...3757653&sr=8-1
  2. #292
    Mod - iPad Forums RipplingHurst's Avatar
    Dec 2007
    Danville, CA
    One problem I'm having in my early testing is that WMP and WMC refuse to play broken .asf files. If I press the stop button, the files play okay, but if just cut the power - running on batteries and switch to dc power (disconnected), the file will be corrupted.
    Upon giving back power the unit restart recording fine. I have to test now if the corrupted files play in the unit.
    ---------- Post added at 08:21 AM ---------- Previous post was at 08:20 AM ----------
    Anyone knows of a nice .asf player, codec, transcoder for windows 7?
  3. #293
    May 2009
    Quote Originally Posted by Liteace View Post
    Ive managed to get 1, its on its way to me now, it'll take a little time as im here:
    http://maps.google.com/maps?f=q&sour...r=Tenerife&z=9
    I'll let you know when it arrives
    Its arrived today, its unpacked, plugged into TV & working. It came with a 128Mb SD card, I took the 8Gb Micro card out my old Blackberry, placed it into a Micro to SD card adaptor but no go, Ive downloaded and upgraded the firmware in the DVR and it now boots with the 8Gb card in. Next on the list is the cameras, i'll keep you posted
    Who am I? HiJackZX1's Avatar
    Jul 2007
    Miami
    Well I finally got the HiJackZX1 back from the shop. During the accident the rear view screen fell of the windshield, taking all the wires and cables for the DVR and interior camera with it. I thought the fuse box would be messed up too because one of the passengers flew into it, but I guess I actually did correctly on setting it up. One thing I have always hated about the DQP add on I did is that everything shows on the wrong side. I'm on the left, but the camera shows me on the right. Its the same situation for all rear facing cameras. I took the DQP out of the car, put it on my TV and reconnected the controls to the DQP (I had to remove them to get the box into my dash.) and looked in options. There is actually a feature to turn on mirror effect. I activated it, now all is good. Also since I am retiring my current car pc, which is much more powerful then my desktop, I can now do proper video encoding without the rubber band effect issue. Ill post videos some time next week! It feels so good to have my truck back!
    1X Ainol Novo Flame Tab
    4X MK808b
    3x Perixx Touchpads
    3x 7 inch Screens
    1X 7 inch motorized Screen
    1x Win 7 PC
  5. #295
    May 2009
    I need some help now with the camera's, I want a good one facing forward, (very rarely drive at night, works van) and a good one inside for night surveillance (motion detection setting on DVR) and maybe a cheaper one as a reversing camera. There are so many out there I dont know where to start, I will have to get a 3 way switch but they are easily available. I do have an Iphone 3Gs, I have removed the rear view mirror (its a van, dont need it) and made a little holder, so it sits there when Im driving, today I moved it over a bit and so the camera wasnt blocked and started recording, its not bad but I would like a camera thats better than the one fitted in the Iphone, is that poss?
    Thanks All
    Jul 2007
    Miami
    Thanks All
    Any mini camera that is CCD based will be perfect for what you want to do. For inside, because its a small space, you can go with a CCD or cheapy CMOS camera. Now seeing that you said the inside image wasnt good, then go with a CCD camera for the inside too. For my rear camera I have it set high enough in the back that I dont have to have a seperate rear camera. Its an always on system.
    Only thing I have to do is 1) move the inside camera back. You cant really see the front passengers faces. 2) Setup the other PC, because this ATOM sucks.
    4X MK808b
    3x Perixx Touchpads
    3x 7 inch Screens
    1x Win 7 PC
  7. #297
    May 2009
    Quote Originally Posted by HiJackZX1 View Post
    Thanks for the info, what forward facing camera are you using, do they all have like a fish bowl effect ? I dont know if im allowed to post URL's here, ifnot please remove, Ive found these:
    http://www.rfconcepts.co.uk/mini_colour_audio.htm
    They look good as they can run on 8.5V to 15V ideal for automotive use BUT anyone know what the difference between the 2 are ?
  8. #298
    Jul 2007
    Miami
    These look exactly like the camera I have on the inside. Only thing is mine has added IR lights for night vision.
    Looks like the difference on the ones you linked to is the lens. One is a wide angel lens, and the other is a pin hole lens.
    I think its the windsheild that causes that fish bowl effect? My forward facing camera is built into the RVS-300 Blackbox system. It is very rounded at the front.
    Here is the inside camera.
    4X MK808b
    3x Perixx Touchpads
    3x 7 inch Screens
    1x Win 7 PC
  9. #299
    Dec 2007
    Danville, CA
    I second the above about CCD cameras.
    I wouldn't go with wide angle for the front forward cameras, they distort too much and they're useless trying to figure out speed and relative position of the cars.
    But for the interior and for the rear, I think wide angle is a must.
    The cameras you linked looks to be fine but I can't know for sure. Both appears to be wide angle lenses though, as it's said in the title "normal lens and pinhole available"; I'm assuming those are not normal, but wide angle.
  10. #300
    May 2009
    Thanks for the info, the inside camera is going to be something like RipplingHurst has behind his grill, that will be fitted in the back of the van facing the rear door. The price over here for the camaras is very expensive, they want €55 for a mini cmos and €98 for a mini ccd, ive seen them on Ebay for as little as $15
  1. Replies: 65
    Last Post: 10-13-2009, 06:51 PM
  2. Watching video while using GPS / web / whatever
    By lastberserker in forum General MP3Car Discussion
    Last Post: 04-19-2005, 02:11 AM
  3. Replies: 21
    Last Post: 02-10-2005, 11:39 PM
  4. Glitchy video when gps running. . . help!
    By PaPP in forum FrodoPlayer
    Last Post: 08-12-2004, 09:42 AM
  5. Mediacar V1.8.5
    By coyote in forum MediaCar
    Last Post: 02-16-2004, 01:16 PM
