Page 6 of 32 FirstFirst 12345678910111213141516 ... LastLast
Results 51 to 60 of 320
Thread: Dashcam video with GPS speed imprint - court date soon...
  1. #51
    Variable Bitrate Uraijit's Avatar
    Aug 2007
    Utah
    To the dude asking about a software solution, check our RRCam here on the forums.
    To the "blue LED" guy... You're off your rocker. Good luck driving around with blue LEDS on your dash. It's a great way to get a fine.
    If you want IR light, get IR LED's. They are there as an illuminator to make objects visible in the dark. Blue LED's on a camera won't do much more than make you look like a jackass...
    Greedy
    -Adj.
    Anybody who makes significantly more money than you do.
    The Hoe-Puter Worklog
    Progress (Phase one):
    Planning:
    [----------] 97.3%
    Parts Aquisition:
    [----------] 95%
    Install:
    [----------] 95%
  2. #52
    Maximum Bitrate LinuxRacr's Avatar
    Jul 2003
    Dallas, Texas
    You ALL are mis-understanding. Not actual BLUE LED's, but blue IR LED. The kind made with the clear-purplish plastic. Geez.
    Maybe this will help "shed some light":
    Click Here
    and
    Click Here
    My Car: 2001 Mazda MP3
    My OLD Carputer project: Here
    Completion Progress Bar: [**********100%]
    Current build! Here
    Completion Progress Bar: [*********99%]
  3. #53
    Aug 2007
    New Orleans, LA
    Mount the IR LEDs on the OUTSIDE of the vehicle FTW. If you wanted a premade item, they make IR illuminators for security cameras that can throw IR light very long distances. And, if you're really serious about things like this, go with a siny or JVC day/night security camera. Color by day, black and white at night, with very low light requirements (usually less that .1 lux).
  4. #54
    Jul 2003
    Dallas, Texas
    I want to say that this is one of the most awesome things I have ever seen! Good job on this!
    Current build! Here
  5. #55
    Aug 2007
    Utah
    Quote Originally Posted by LinuxRacr View Post
    Click Here
    and
    Click Here
    Ahhh. See there's a pretty good difference between "Blue LEDs" and Blue IR LEDs.
    Greedy
    -Adj.
    Planning:
    [----------] 97.3%
    Parts Aquisition:
    [----------] 95%
    Install:
    [----------] 95%
  6. #56
    Jul 2003
    Dallas, Texas
    Indeed. LOL! I violated my own rule:
    "Be clear, and specific".
    Current build! Here
  7. #57
    Aug 2007
    Utah
    No worries
    Greedy
    -Adj.
    Planning:
    [----------] 97.3%
    Parts Aquisition:
    [----------] 95%
    Install:
    [----------] 95%
  8. #58
    Maximum Bitrate FusionFanatic's Avatar
    May 2007
    Boston
    Quote Originally Posted by nobb View Post
    I am also interested in a more software based solution that can be integrated into the carputer. I have found a program called Digiwatcher, where I can connect a standard usb webcam and have the program automatically record. The great thing about this program is that it can automatically delete video files after a set amount of days, so it can be pretty maintenance free. I couldnt find any other program which does this. However...I am not sure how I would go about integrating the gps overlay. I think to have a gps overlay on the actual video file might hold up better in court than to have a separate program which records your location and speed and then having the judge to compare the two files.
    a GPS overlay on that actual video is the ONLY thing that would hold up in court. I don't think that a judge would consider 'comparing' two seperate files to be proof of anything.
    that being said, the easiest (and probably the only) way to integrate the GPS overlay into a carPC would be to ditch the webcam and get a standard RCA-out video camera. the video would go from the camera to the GPS overlay device, then into the carPC (via an RCA video input, or through an RCA-->USB video converter). the carPC can then record and/or monitor the video after the GPS info has already been overlayed via hardware. this method has two advantages over software, 1.) since the information was overlayed in hardware it should hold more water in court, and 2.) constant text overlay while simultaneously recording incoming video, running GPS software, audio software, etc. may be too stressful on older/slower machines. since many carPCs are slow by today's desktop standards (mainly to reduce power consumption and heat output), trying to juggle all those tasks at once may be too much for some/most systems to handle.
    either way, it doesn't look like it can be done cheap. I've goggled my @ss off and have found only a couple GPS-video overlay devices and they are not cheap (the one that erkme73 used costs almost $200, and the newer model with the integrated GPS receiver costs $285 ). but to be fair, the $200 spent on the device would pay itself back if it gets you out of an exaggerated speeding ticket
  9. #59
    Aug 2007
    Utah
    For those of us using RoadRunner, there's a great software-based solution. It's called RRCam, and it can overlay any information that RoadRunner can output to display in the skin.
    The current release (2.0) is only capible of operating one camera. But the next release is supposed to have multiple camera support. It operates USB cameras.
    I currently have it set to overlay GPS Time and Date, GPS Speed, Latitude and Longitude, and heading. Check out the screenshot.
    Greedy
    -Adj.
    Planning:
    [----------] 97.3%
    Parts Aquisition:
    [----------] 95%
    Install:
    [----------] 95%
  10. #60
    Sep 2007
    Quote Originally Posted by Uraijit View Post
    What screenshot Austin?
  1. Replies: 65
    Last Post: 10-13-2009, 07:51 PM
  2. Watching video while using GPS / web / whatever
    By lastberserker in forum General MP3Car Discussion
    Last Post: 04-19-2005, 03:11 AM
  3. Replies: 21
    Last Post: 02-11-2005, 12:39 AM
  4. Glitchy video when gps running. . . help!
    By PaPP in forum FrodoPlayer
    Last Post: 08-12-2004, 10:42 AM
  5. Mediacar V1.8.5
    By coyote in forum MediaCar
    Last Post: 02-16-2004, 02:16 PM
