Is it this model antenna that you use:
http://store.mp3car.com/ProductDetai...Code=COM%2D008
Does this antenna connect directly to the antenna outlet on the ET301 or is there an converter cable that is required? Thanks.
I use the ET301 with the roof mount antenna that's sold here on the store.
Works very well, all of the time in StreetDeck as well as with iGuidance.
Jan Bennett
08 Lincoln Navigator www.mobiteklink.com
Most OEMs are not that sensitive, as well as expensive and hard to find a decent one.
Get a USB SIRF3 GPS with ext ant connection off ebay, stick an active ant and you are done. Its much cheaper and better than the hyped up outdated OEM modules poeple are on about.
Anyone name me or link me a decent OEM module for a good price, I bet no one dare
Honestly if reception is the issue then you might wanna consider GPS with DR. As been said before, its not really the OEM style that make it more sensitive, its the chipset and the antenna that matters. If you already have a SIRF3 chipset, then just add and active ant and yours will be as good as the so called OEM or even better, + it comes in a box![]()
Would something like this work?
http://cgi.ebay.com/Holux-GR-213-USB...QQcmdZViewItem
I think you are missing the point. The OEM is reffering to just the receiver such as this: http://www.sparkfun.com/commerce/pro...oducts_id=8266
Notice just the receiver. No USB controller, no enclosure, no antenna.
What you posted is just a regular gps puck. Yes it will work, but not the entire point of this thread.
1.9in x 2.9in -- 47mm x 73mm
How did you have the GPS mounted? I know my Hollux got crappy reception some times, then I realized I didnt have it mounted on a good ground plane. I stuck it to a section of steel and everything started working perfectly... I don't see how an OEM would do any better unless you are adding external Active antennas etc... which you can do w/ some cheapo's anyway.
who are you talking to bimmerman?
Jan Bennett
