All of the satellites my GPS is hooking up to seem to be grayed out. I can't get a signal from any satellite. I do get a time signal, but I can't get a location signal.
I am using Iguidance 2.1.3 and running a Holux GR213 reciever on Com3 at 4600 baud. OS is Windows XP, all proper drivers are installed. I even tried reinstalling them! Reinstalled Iguidance.
Any suggestions? As a side note I also noticed that in the past the light on the GPS reciever used to blink, and now it just stays solid orange.
--L
whether its roof mounted, or mounted internally on top of my scooby's dash(right dead center between the two heating vents) same results. It worked for a period of time...and then it just stoppedI dunno why...
1.9in x 2.9in -- 47mm x 73mm
I see some stuff being passed...it is able to collect the "exact" time...however then it is UNABLE to get any location information.
It's a GR213 thing...
Basically it has something to do with the internal locking battery/chip combo.
Find the configuration software on the Holux Website and see if it works 2 mins after doing a Cold Start.
It should...
The Software.
It's called GPSViewer. Try it out in your car, it's gonna have the three Start options.
For Sale: Carputer (CarPC) & RCA Y-Adapter
Newsflash: Take a look at my unsold stuff above, thanks!
Up Next: Make an OBD to Serial cable & Redo the "MMI buttons"
