Results 1 to 10 of 11
Thread: GPS Receiver in 2.0 vs. 1.1 ports
    Low Bitrate Queenambeach's Avatar
    Apr 2006
    Cool GPS Receiver in 2.0 vs. 1.1 ports
    Will having the GPS receiver plugged into a 2.0 high speed USB port
    over a 1.1 have any bearing on how fast it updates itself in
    the software program?? In most of the OEM navigation systems, along
    with some of the aftermarket ones (Kendwood, Pioneer, Eclipse) the
    movement of one's position seems to have a continuous flow, versus
    mines which has a more jerky forward movement. I know the sirf III
    have a max refresh rate, but since I have 1.1 USB ports, I was wondering
    if this could impact it also.
    oh and by the way. I SEARCHED!!
    Takes it in the Rear kevinlekiller's Avatar
    Dec 1969
    Where the penguins and polar bears live.
    I don't think it makes a difference. It gets changed to serial with software. And I think serial is 115kbps? and usb is like 480?
    What can I say? I like serial. Curiosity's Avatar
    Mar 2004
    Florence Yall, BFKY
    I believe they all use a 1.1 interface, so it doesn't make a difference.
    Raw Wave Rob Withey's Avatar
    Apr 2000
    Bedfordshire, UK
    No difference. 1Hz NMEA doesn't even get close to the bandwidth available.
    Dec 1969
    Apr 2006
    Cool
    Quote Originally Posted by kevinlekiller View Post
    Okay, thanks for the link. I just got off the phone with Semsons and Sons Inc. because I almost bought the Evermore SA-320-5Hz GPS receiver. What customer support told me was that these receiver will work with our mapping software like (MS&T, Iguidance, Street Atlas, etc) but they wouldn't be able to take advantage of the 5Hz refresh rate because the program only allow a max rate of 1Hz. That sucks!!
    Feb 2007
    Taylorsville, UT
    No, the gps operates at 4800-9600 baud, that 4.8 to 9.6 kilobits per seond. A dialup modem is 56 kilobits per second for example and Usb 1.1 is 12 megabits (12,288 kilobits) per second. That means USB 1.1 has over one thousand times the required bandwidth. Usb 2.0 is 480 megabits.
    -James
    Car: 2004 GTI VR6 24v Turbo 2.8L, GT35R, 630cc, Unitronic, Bosch 044, etc, etc..
    Main PC:i7 920@4Ghz, 6GB DDR3, MSI X-58 Pro-E, Win 7 x64 RTM, Scythe Mugen2, 128GB G.Skill Falcon, 2x ATI4850 512MB Crossfire, Auzentech X-Fi Forte, Grado Labs SR-80
    Mar 2004
    Florence Yall, BFKY
    There's a refresh rate hack for S&T but I don't know about the others.
    http://www.mp3car.com/vbulletin/show...51&postcount=9
    Apr 2006
    Cool
    Quote Originally Posted by Curiosity View Post
    But isn't this to help older version of S&T refresh quicker. Unless I'm wrong, this patch will refresh at 1Hz per second. I already have that. I'm trying to get the OEM type of refresh rate that will update my GPS position 5x per second.
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    The only problem I see mixing USB 1.1 devices and 2.0 is the speed of 2.0 devices. Some cheap hub, it will make all USB 2.0 devices to run at USB 1.1 speed. So if you put gps receiver (1.1) to a usb 2.0 hub, make sure other device are also usb 1.1. So try to separate usb 1.1 into different hub than those usb2.0.
    The 2nd problem is they may or may not wake up from hibernation.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
  1. No review needed for this GPS receiver BR-355
    By kickercivic1 in forum GPS
    Last Post: 05-23-2006, 12:07 PM
  2. Replies: 11
    Last Post: 08-18-2005, 11:02 PM
  3. what to look for in a GPS receiver?
    By doublestack in forum GPS
    Last Post: 10-01-2004, 04:05 PM
  4. i have a cf gps receiver
    By ombastic in forum GPS
    Last Post: 07-08-2004, 03:34 PM
  5. Got my Navman RandMcnally USB GPS NMEA 2.0 compliant receiver.
    By LESLIEx317537 in forum General Hardware Discussion
    Last Post: 03-13-2002, 03:54 PM
