Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: 5hz anyone?
  1. #11
    Dec 2006
    great thing if it works.
    Could someone explain to me though why other chips, like the sirf III, limit them self to 1hz if it is perfectly fine to get higher update rates? I mean theres gotta be a reason why all other receivers update more slowly. Moreover why stop at 5 hz?
  2. #12
    Mar 2006
    Colorado, but Canadian!
    guess #1: To keep costs low...
    1.9in x 2.9in -- 47mm x 73mm
  3. #13
    FLAC Marvin Hlavac's Avatar
    May 2005
    Quote Originally Posted by 2k1Toaster View Post
    What 2 second delay? Mine is updated at 1Hz. When I move, it is always t<1sec before I see a move on the screen. If there was a 2 sec delay, if I was stopped it would take t < 2sec to get movement.
    If you estimate the delay between what you see on your screen while driving and your actual location to be less then 1 second, than you do have a very good system. My setup in my estimation generates greater delay. Two seconds is my best guesstimate. I think that's quite reasonable considering that 1Hz of a GPS receiver gives us about 1 second delay, plus the GPS software accounts likely for another 1 second.
    [EDIT] I re-read your reply and I just realized you are likely not talking about the delay between the GPS position on the screen vs. actual location on the road while in motion. I think you are referring to the screen refresh rate only. In that sense you are correct.
  4. #14
    Maximum Bitrate MobiTekLink's Avatar
    Jun 2005
    Queens, NYC
    Im more interested in Dead reckoning. Both would be nice but hz are probably third on my list.
    1. Dead reckoning.
    2. Better maps, more POI's
    3. HZ
    08 Lincoln Navigator www.mobiteklink.com
  5. #15
    Oct 2004
    NY
    I use an alpine navigation unit in my minivan, & I have iguidance & a few others on the pc... I notice the least "lag" with the alpine, it is dead reconing though, so maybe that makes a difference? with iguidance I'd say 2 second lag sounds about right to me... the alpine is almost half as much, but still theres a slight delay from where I actually am to where the screen shows I am..
    strange thing is, my bu 353 is really fast & gets a lock in seconds,but the alpine with a system reset, it starts up in cali default again, it takes a few minutes to get a lock & locate me... wonder if a better antenna would make the alpine better? it should... hmmm
  6. #16
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    Quote Originally Posted by turbocad6 View Post
    It's strange because I have a tomtom go 300 that I use in my girlfriends car and it takes a really long time to find my location, even if I dont move the GPS from where I last turned it off. I guess i'm just spolied by my oem module that has a lock before the computer even gets fully running.
    肚子笑痛了
    S60 Install
  1. First Pics: Tyco GPS Dead Reckoning Receiver
    By LiquidKernel in forum GPS
    Last Post: 03-05-2007, 02:44 PM
  2. DR or 5hz?
    By Mad Jad in forum GPS
    Last Post: 09-14-2006, 02:46 AM
  3. Garmin GPS 18 5hz
    By Dwaine in forum GPS
    Last Post: 04-15-2006, 11:51 PM
