Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: RR - iGuidance 3.0 embedding Solutions Consolidated.
  1. #11
    Feb 2006
    Vancouver, BC
    I found out what my problem is but not my solution. I reinstalled RR and left it with the default BMV2 skin. Selected the GPS button and boom, there's Iguidance without the warning screen. Fantastic! But what that means is that the skin that I want (Simplistique), does not open Iguidance when I select the GPS button. Why would that be the case? I'll guess I'm going to PM the creator to see what's up.
  2. #12
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    Quote Originally Posted by guizai View Post
    You have to modify the skin file.
    Take a look at the Menu.skin or any skin that has the GPS button, and check to see what code the that button execute. Some skinner just put the command as "GPS" which default execute whatever your gps option in RR.ini. Other skinner choose to execute the GPS button with a RUN/LOAD command and that is different from one another.
    If it run with the default BMV2 skin, it runs as it shoud be. You can try the skin I modified called "CFX Re-work". It was created to work with iGuidance well.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
  3. #13
    Car Audio Moderator durwood's Avatar
    Sep 2006
    Chicagoland (St. Charles,IL)
  1. Frustrated with RR and IG3 embedding...
    By Pseudo Nim in forum Road Runner
    Last Post: 08-19-2007, 01:43 PM
  2. RR and iGuidance
    By robsch in forum Road Runner
    Last Post: 01-13-2007, 03:01 PM
  3. RR & Iguidance problem
    By tsx004 in forum Road Runner
    Last Post: 12-05-2006, 05:57 PM
  4. Need Help On IGuidance 3.0
    By XCaLiBuR1085 in forum Newbie
    Last Post: 07-29-2006, 06:31 AM
  5. RR doesn't start Phoco on initial load..
    By DutchBurner in forum Road Runner
    Last Post: 11-04-2005, 02:17 PM
