you need to make an external_gps.skin file as well as modify the external_gps.jpg to look as you want.
I've read through all the threads pertaining to ignative=true|false and all that stuff. I have mine set to true and everything works good, except for the map disappearing thing, but I can kinda live with that since all you do is touch the screen and it comes back. I can't find any information on how exactly to add a menu bar to the top or bottom of the Iguidance window in RR to change songs and stuff. If anyone has one and would show me where to get the file and where to place it, I would be VERY appreciative as this is the only thing holding my back from installing my CarPC in my New Audi A4.
Also, what is this thing called "clipping region"? I've done searches and I can't find any good explanation of what it is or where to find it or what I need to do with it. I'm using the BMV2 for Audi skin and can't find any reference to it in it's folder.
Thanks guys.
2006 Audi A4 2.0TQ6MT
Mods:
APR 93 Tuned
Stasis SS Coilovers
OEM RS4 Rear Sway
Votex Skirts\Front Spoilers
Deval Rear Spoiler
18" BBS CO
CarPC:
Dell Latitude D600
Pentium M 2.00 GHz
1.5 GB RAM
Windows XP Pro
R.R. Front End
Xenarc 700 IDT
1.9in x 2.9in -- 47mm x 73mm
Open the external_gps.skin file with notepad, and put a forward slash "/" in front of all the lines that start with a "c"
Make this:
into this:Code:/, C, x, y, w, h C01,000,055,800,545
That will get rid of the map disappearing thing.Code:/, C, x, y, w, h /C01,000,055,800,545
As for changing the skin, Check here and here.
Yeah google!
Thanks for your help guys, I will give that a shot.
Mods:
APR 93 Tuned
Stasis SS Coilovers
OEM RS4 Rear Sway
Deval Rear Spoiler
18" BBS CO
CarPC:
Dell Latitude D600
Pentium M 2.00 GHz
1.5 GB RAM
Windows XP Pro
R.R. Front End
Xenarc 700 IDT
strange iguidance behavior
http://www.mp3car.com/vbulletin/gps/...t-working.html
I don't know why it works, but it is what I needed to do.
Yeah google!
Ignative=true then you remove the clipping region...otherwise, not.
My Work Thread:
http://www.mp3car.com/vbulletin/show-off-your-project/72552-mp3-project-for-land-cruiser-done.html
Source switcher for Lill
http://www.mp3car.com/vbulletin/show...d=1#post841007
As for skin comment in stead of just forward slash "/", it should be forward slash and a comma as "/,"
so instead of
It should beCode:/, C, x, y, w, h C01,000,055,800,545
You see the line above the clip code? /, C, X ....Code:/, C, x, y, w, h /,C01,000,055,800,545
OP, look and try other skin as well.
Y2K Accord Dell GX150
EmoRebellion is a SCAMMER
