Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: audio signal to ground or power signal
  1. #11
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by durwood View Post
    The MUTE signal wire on a headunit will mute the headunit when the wire sees a ground, not 12V. At least that is how it usually works. The MUTE wire is usually used to mute the audio so you can hear an incoming phone call and that is how it works with handsfree phone car kits. .
    doh!
    I completely missed the "for a transmission" part.
    In that case, then just invert it either with a transistor or use the other pins on the relay for NC instead of NO.
    Not too bad.
    Again, I have never done this, or know how well it would work. It might induce quite a bit of noise to the system, or stare WWIII, I dunno.
    1.9in x 2.9in -- 47mm x 73mm
  2. #12
    Car Audio Moderator durwood's Avatar
    Sep 2006
    Chicagoland (St. Charles,IL)
    the only thing he didn't say was if he has his audio running through amps or the HU? If he has aux in or the amps, then he would have to build some relays to switch the RCA audio signal back and forth. If there is no aux in or no amps, I don't know what his "transmission" will play over. I don't think it would start WWIII but maybe send signasl into space like Contact
  3. #13
    Constant Bitrate henkbliek's Avatar
    Dec 2002
    Netherlands
    Guess something like this should do the job...
    white bream
    working on a trilogy: CARGO - UNIGO - MERGO
    CARGO = the Car Computer
    Intel Celeron M, [P]SDC, uBlox GPS, GPRS, WLAN, Silabs FM, RDS, TMC,
    Dual-audio, Onecable TFT, Microsize: 45 x 108 x 168mm (1.8 x 4.3 x 6.6")
  4. #14
    Oct 2006
    Las Vegas
    the signal sent over the rca cables is not AC. AC by definition passes through zero. This is more of a fluctuating DC, like an AC signal already riding a DC bias. A rectifier does no good there, as the signal doesn't pass through zero. What about an inverting, comparator op amp. This would give high input impedance, as seen by the scanner, could bump up the signal to a desired level to keep the mute off when wanted. Filter it's output for noise and to keep the opamp from turning on the mute function erroneously.
    It's been a while...
  5. #15
    Mar 2006
    Quote Originally Posted by h3rk View Post
    Well the rectifier will make sure that the signal is going the right way. Without the rectifier, if you connect the wires backwards, it will not work. So for like $0.04 in diodes, you get the lazy man's circuit.
  6. #16
    Oct 2006
    Las Vegas
    Fair enough.
  7. #17
    Jul 2005
    If what h3rk said about the the RCA line not containing AC is correct an op amp set up as a comparator is the way to go. In this setup the op amp will effectively form the rectifier, peak detector and amplifier functions for you. The only problem i can see with the idea is that the op amp wont output a proper ground when you want it to if you use a OV source on on of the op amps supply pins. You'll actually get 1V or 2V. If this is enough to mute the head-unit then fine. If not you'll need to use around -1 or -2V supply voltage to get an output of 0V. You could use a potentiometer to adjust it to get exactly 0V output.
    The risk here is that you could potentially output a negative voltage to the head unit and I don't know what side effects that may have.
    Spuzzdawg
  1. OEM Navigation Connectors
    By Mr Castulucci in forum General Hardware Discussion
    Last Post: 07-20-2010, 06:25 PM
  2. Converting an Audio Signal to a Voltage
    By ukchris in forum Car Audio
    Last Post: 08-19-2008, 07:32 PM
  3. FAQ: Power Supplies Explained (Part 1)
    By Bugbyte in forum The FAQ Emporium
    Last Post: 06-10-2007, 08:45 AM
  4. How exactly do you ground the audio wire?
    By SuperAJ in forum General Hardware Discussion
    Last Post: 01-03-2003, 09:46 PM
  5. power good signal - help me please!
    By BluCivic93 in forum General Hardware Discussion
    Last Post: 08-10-2000, 11:16 PM
