To get 8 channels, you will want to use a ULN2803. You must check the device specifications to be certain this device supports the maximum current you require. According to the ULN2803 datasheet (available on digikey.com), all 8 outputs active can sustain 150ma per output at 70C ambient temperature. If you only have 2 outputs active at a time, then you can sustain 400ma per output.
If you use bit-bang mode in the FT245, you can wire DB7-DB0 directly to the IN8-IN1 pins of the ULN2803 driver chip.
If you hook up an external microcontroller to the FT245, you can do even more (more channels, more features). You would use the FT245 as if it were a serial port and transfer data in/out using the FIFO control signals. Read through the FT245 datasheet to see how the FIFO control signals work and for some simple examples of interfacing to a microcontroller. This will require you to write some code in the microcontroller to fetch data from the FIFO and write it to the outputs connected to the ULN2803 driver. This also gives you the ability to add some inputs on your microcontroller and push the data back up to your application running on the PC.
Thanks,
Mark Stubbs
http://www.bibaja.com
LinkBack URL
About LinkBacks
