+ Reply to Thread
Results 1 to 6 of 6
Thread: Below 40F won't start VGA properly
    FLAC DodgeCummins's Avatar
    Oct 2000
    DFW area
    Well summer is arriving fast, so this won't be an issue...or replicatable for a while...
    However, on my system with mini-itx mobo and pci video card...
    ...below 40 deg F will not start the VGA...sometimes it won't boot at all...sometimes it only doesn't start the VGA card.
    I am running the OPUS, so if I turn it off, and turn it on again (after the built in OPUS timers run 10sec on and 20sec off) then it boots normally.
    I thought maybe it was voltage, but there was no correlation...i.e. weak battery warm days still boots normally.
    Possibly could be somehow condensation...but there isn't on any other surface...I haven't had the lid off during these mornings.
    I have not plugged a monitor into the built-in vga out...so I don' know if it is unable to boot the pci card and defaults to the internal video.
    Any ideas from the audience?
    Oct 2000
    DFW area
    Tried it this morning...it completely booted but ignored the installed VGA card. (I opened everything up and hooked the display to the onboard video).
    So it is as if the PCI card isn't booting fast enough for the mobo to see it.
    Aug 2005
    Pennsylvania
    Did you try disabling the onboard vide card or setting the PCI or AGP card to display first in BIOS?
    Dec 2006
    I have the same problem and no add-on cards.
    I originally thought it was my HDD not being able to spin up fast enough due to the cold, but I don't think that's it. I've been debating getting some kind of thermostatic switch to cut power to the Opus PSU at anything under 40F to prevent the system from trying to boot.
    Newbie Wickerswammie's Avatar
    Apr 2006
    North Carolina
    Lilliput LCD?
    I had the same issue, and I have a Lilliput LCD. I figured out that the issue was caused by a capacitor that "almost" touches the on-board transformer.
    It was only an issue in the cold for some reason, and it would cause an arc of electricity to go from capacitor to transformer.
    Once I had figured out the issue, my capacitor had a lot of charring, so I had to replace it to reduce the chance of the capacitor going bad.
    I hope this helps
    Sep 2006
    I have this issue too with my J7F2, it will not boot properly if it is cold but then if I just hit reset it boots up with video perfectly.
+ Reply to Thread
  1. Centrafuse RC4.1 Release Notes
    By veetid in forum Centrafuse
    Last Post: 10-19-2006, 04:32 PM
  2. VGA PSone LCD and Csync Composer mods for sale
    By dagnasty in forum General MP3Car Discussion
    Last Post: 01-12-2006, 10:22 AM
  3. PSONE LCD VGA csync composer mods
    By dagnasty in forum Newbie
    Last Post: 01-09-2006, 12:11 AM
  4. VGA vs RCA & Touchscreen vs other
    By integsrtite in forum LCD/Display
    Last Post: 12-02-2004, 07:07 PM
  5. vga -> composite -> vga (possible?)
    By Nav_Attack in forum LCD/Display
    Last Post: 04-03-2004, 12:38 PM
