Page 4 of 6 FirstFirst 123456 LastLast
Results 31 to 40 of 54
Thread: HDTV Over the Air for your CarPC!!
  1. #31
    bmo
    bmo is offline
    Low Bitrate bmo's Avatar
    Feb 2005
    ohio
    I am currently trying this out. I bought a wintv usb950 hdtv tuner. It works great in the home, with a normal antenna. When Install it in the carpc, the program works great but the reception is not that good. I am trying to use the factory powered bmw antenna in the rear window. I made an adapter to plug intot the factory to the usb tuner. Then I am powering up the antenna power with a switched source. It seems that when I power the factory antenna the reception gets worse... If I slightly unplug the antenna from the usb tuner so the ground is removed(shield) the reception is better with it powered. But still not that good.
    I was wondering if anyone might know why this is happening, For right now I got a stick-on powered type antenna that works okish but looks like poop. I am hoping to get the factor on to work.
    Thanks for any help
    Brian
  2. #32
    Newbie impala454's Avatar
    Aug 2007
    Houston, TX
    Just wanted to clarify (I hate seeing this spread around incorrectly). The 2009 switch to digital has absolutely nothing to do with HD. It doesn't mean everything will become HD. It doesn't mean your TVs will cease to work. All it means is that the frequency range currently being eaten up by old, analog, over the air broadcasts is being converted to a digital format. The only people affected are people who currently recieve their TV programming via a non-digital TV connected to an antenna. Anyone using cable or satellite is unaffected.
  3. #33
    High Voltage blk02si's Avatar
    Jul 2005
    Motorcity
    Blog Entries
    1
    So you cannot watch HDTV while in motion because of the software/legal issues?
    Or is it you cannot watch HDTV while in motion because the antenna does not work and you get fuzz?
  4. #34
    Low Bitrate Chamberlin's Avatar
    Aug 2006
    Tucson, AZ
    I would bet a little of both....
    I know HDTV OTA is pretty touchy when it comes to signal lock on, as I use it at home on my living room TV... I can imagine being stopped in the car will give best results.
    I can't speak about the laws, but I would also guess it violates some law if you can see the moving pictures while you are driving...
    -C
  5. #35
    Jan 2003
    Quote Originally Posted by blk02si View Post
    Atleast in California you can have any video in front or in view of the driver. You can have video while the car is moving. The way signals are set up for HDTV, you can't watch HDTV while the car is in motion. If you are going ~2MPH you can still get signal, anything higher won't work. I'm sure engineers can come with a solution to get HDTV while the car is moving if they wanted to.
  6. #36
    Apr 2006
    Sydney, Australia
    Has anyone got more details on the Mini PCI card tuner ?
    New Car PC Build list in progress
  7. #37
    Aug 2006
    Tucson, AZ
    Looking to install mine, once I revert my OS from 64 bit Vista to 32 bit Vista... I can't find much tech info on this card unfortunately, but I at least think I found drivers for vista a while ago. I did try to install this card into my laptop in the meantime, but I couldn't find a suitable mounting jack port for the antenna jack, so I gave up before completing the install.
  8. #38
    Oct 2007
    Houston
    Quote Originally Posted by moahdib View Post
    I got a Pinnacle PCTV HD USB 2.0 Pro Stick off ebay and decided to try it out and OMG... its amazing.
    Now go out and get one!!!
    Got mine running outside of RR. . Do you have a skin that you're using this tuner with inside RR? Would you mind sharing?
  9. #39
    bmo
    bmo is offline
    Feb 2005
    ohio
    just a small update, if you do a google search for dvb-t antennas there will be a ton of car hdtv antennas, but they are all in the uk and such. Alpine makes a hd tuner for the car but of course its only a over seas part.
    I emailed a couple of online sellers in the uk, but as always they never email back.
    Maybe one of the uk members could hunt down a antenna from over there...
    There is no in-motion blocking. I can get some what of a signal on the freeway of and on.
    I am still searching for the right antenna. I am sure we will se alot more coming out when they make the change from analog to digital. If not there will be alot of RV and van people very up set.
    bmo
  10. #40
    Dec 2006
    Car TV antenna
    Might wanna check this out. It installs between the roof and headliner of the car:
    http://qualitymobilevideo.com/Mercha...ct_Code=TVA20K
  1. For Sale: CarPC EZ v.2.5d
    By stevent76 in forum Classified Archive
    Last Post: 12-23-2005, 08:55 PM
  2. CarPC Gets BLACKOUT! when monitor is connected!
    By Sympotonic in forum General Hardware Discussion
    Last Post: 12-08-2005, 03:30 PM
  3. CarPC PictureViewer! works with ALL engine
    By dragonBTV in forum Software & Software Development
    Last Post: 02-02-2005, 08:56 PM
  4. fans
    By LudeAtude in forum General Hardware Discussion
    Last Post: 04-23-2004, 12:55 PM
