Results 1 to 4 of 4
Thread: relais on dtr?
    May 2006
    Belgium
    relais on dtr?
    hi,
    to control my amps i use pin 4 of my serial port and the service that raises power on that pin when pc is turned on.
    this works all very well, but now i want to connect a relais to pin 4, so i can use a regulated 12v to switch on my amps (instead of the 10.7v pin4 is giving me)
    anyway, when i want to do this, i'm gonna need more then just pin 4 (also a ground), but when i use a ground and pin 4 to close the relais, all works fine, but when i turn off my pc, pin 4 gives me -12v instead of 0v, turning the relais back on...
    is there a way to avoid this? so, either way have 0v on pin 4, or make my relais not turn on when there is -12v on it?
    Greetz
    Dj NRG
    May 2006
    Belgium
    made a little scheme to make things more clearly:
    Raw Wave Rob Withey's Avatar
    Apr 2000
    Bedfordshire, UK
    Hint : A diode will prevent current flowing backwards.
    May 2006
    Belgium
    so soldering a diode between dtr and the relais would fix my problem? (i'm really a noob in this) or do i need 2 diodes (1 between dtr and the relais, and the other between the relais and the ground, and switch the second one around)?
    and can a normal diode handle the amperes coming from the serial port?
    Greetz
    Dj NRG
  1. Windows Service that raises DTR on powerup
    By Da_Teach in forum Software & Software Development
    Last Post: 04-21-2011, 04:27 AM
  2. Does anyone have the windows service dtr program?!
    By thenick100 in forum Car Audio
    Last Post: 01-31-2006, 08:42 PM
  3. Raising/lowering DTR for switching amp on and off
    By GreenBeast in forum Power Supplies
    Last Post: 08-22-2005, 07:09 AM
  4. DTR use as remote help
    By Ascension in forum Software & Software Development
    Last Post: 07-03-2005, 12:10 PM
  5. Program or batch file to control DTR on a serial port
    By percyt2k in forum Software & Software Development
    Last Post: 12-17-2001, 03:41 PM
