Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: louder output from external soundcard
  1. #11
    _
    Mar 2004
    Little Elm, Texas
    Quote Originally Posted by Dj-[NRG] View Post
    what are the output voltages of my soundcard?
    my amps can handle voltages between 0.3v and 6v...
    Greetz
    Dj NRG
    Audigy 2 usually has 2v outputs.
    The live stuff is probably around .5v.
    I'd look at a line driver.
    Jan Bennett
  2. #12
    Saturated_Fat's Avatar
    Dec 2005
    Rockville, MD
    Live sucks, Turtle Beach Roadie (the $90 one) is great. I used this in a headunit-less install and had no problems, sounded better than my stock headunit.
    Shotgun! - An Advanced CarPC Software Solution!
  3. #13
    Maximum Bitrate tn6478's Avatar
    Jun 2006
    Houston, TX
    Hi,
    I was wondering if there is a way to make your soundcard output louder?
    i'm using an external creative soundblaster live! ( http://www.creative.com/products/pro...&product=10702 ), but i have to put my amps to the max to get nice loud music... if i would connect a headunit instead of my pc, i'm sure it would play louder...
    so, is there anything i can do to get it louder? (some setting in windows, place something between soundcard and amps, ...)
    Greetz
    Dj NRG
    Get an AUDIO CONTROL 3.1 That will fix your problem and sounds great also
  4. #14
    Mar 2007
    I agree with pcfreak, make sure your software/computer is set up correctly first, before you start blowing wads of money on new hardware.
  5. #15
    Aug 2004
    never said i have problems with my amps, i was just wondering if there was a way to raise the output from my soundcard, so the output would be the same as from a regular headunit...
    Greetz
    Dj NRG
    Honestly I don't think a new soundcard is gonna help you. They are made for PCs that work in the home. All home audio/video equipment runs off a standard line-out voltage. This is why your TV doesn't have an audio gain for when you hook up your DVD player
    The problem is that there is no "regular headunit" output voltage since car audio uses varying line out voltages to help with sound quality.
    It's ok for the gains on the amps to be all the way up as long as it matches the input voltage, but this may increase noise I think that's why better headunits have higher preamp out voltages to begin with tho. I think 0.5v is the home audio standard
    If the max gain setting for the amp can't match the soundcards output, pick up a line driver as suggested
  6. #16
    Mar 2007
    South Australia
    or you could get a sound card with a decent output, i have a hippohifi bloat http://hippohifi.com/ it claims to have an output of 4.1 volts. the head desk it was replacing was an alpine with claimed 4 volt output.... let just say that when i took the head unit out and put in the car pc with the bloat usb sound card i had to turn my gains on the amp down from full to 50%. the bloat seriously has a huge punch to it, damn good quality too!!!
    PS I'm running DLS amps... good quality ones
  7. #17
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    Quote Originally Posted by RedGTiVR6 View Post
    I had the live card with an audiocontrol 24xs x-over/linedriver and it sounded pretty good. make sure to also load up the kxdrivers
    Quote Originally Posted by Saturated_Fat View Post
    I disagree with you and i bet the masses out there that are using them with the kxproject drivers would back me up. the live is way more customizable and sounds good when properly set up.
    not a hard goal to achieve
    Quote Originally Posted by vqstatesman View Post
    (it's a dac not a soundcard )
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
  8. #18
    May 2006
    Calgary, Alberta
    Quote Originally Posted by greenman100 View Post
    I found the problem
    Hilarious! I was about to post the exact same thing!
    Ampie Case
    256 MB DDR2 PC5400
    Xenarc 700TSV - VGA Monitor
    Intel D945GCLF Motherboard
    M2-ATX-HV
    2005 Honda Civic
  1. Replies: 11
    Last Post: 09-13-2011, 12:14 AM
  2. HQCT software development
    By Putput in forum Software & Software Development
    Last Post: 06-10-2010, 03:33 AM
  3. Replies: 3
    Last Post: 06-05-2007, 07:10 PM
  4. Problem with Soundblaster external
    By PootsworthIII in forum Car Audio
    Last Post: 06-07-2006, 04:37 PM
  5. Uh oh. No audio from my soundcard..
    By braidy in forum Car Audio
    Last Post: 02-05-2006, 12:59 PM
