Results 1 to 10 of 18
Thread: louder output from external soundcard
    May 2006
    Belgium
    Hi,
    I was wondering if there is a way to make your soundcard output louder?
    i'm using an external creative soundblaster live! ( http://www.creative.com/products/pro...&product=10702 ), but i have to put my amps to the max to get nice loud music... if i would connect a headunit instead of my pc, i'm sure it would play louder...
    so, is there anything i can do to get it louder? (some setting in windows, place something between soundcard and amps, ...)
    Greetz
    Dj NRG
    Variable Bitrate pcfreak's Avatar
    Dec 2005
    Freeport, IL.
    I have the same soundcard, output to 3 amps, and I have no issues with loudness. I'm gonna have to guess and say it's a software issue somewhere.
    Peese
    _
    Mar 2004
    Little Elm, Texas
    the issue is the voltage output of the sound card its self.
    it's too low for your amps.
    what amplifiers are you two running?
    higher end amplifiers can get away with lower input voltages, while cheaper amps will have problems.
    Jan Bennett
    May 2006
    Belgium
    Hi,
    I'm using 2 amps, one for my sub and the other for my other 4 speakers
    Sony Xplod XM-SD22X for my suub
    Sony Xplod XM-SD46X for other speakers.
    right now the sound is good, but i have to turn my amps almost open to the max...
    somewhere i read that a soundcard gives a lower output than a regular headunit... so i was wondering if there was a way to make the output from a soundcard the same as the output from a headunit...
    Greetz
    Dj NRG
    Fusion Brain Creator
    Mar 2005
    Quote Originally Posted by Dj-[NRG] View Post
    Sony Xplod XM-SD22X
    Sony Xplod XM-SD46X
    I found the problem
    May 2006
    Belgium
    Quote Originally Posted by greenman100 View Post
    I found the problem
    May 2006
    Belgium
    what are the output voltages of my soundcard?
    my amps can handle voltages between 0.3v and 6v...
    Greetz
    Dj NRG
    Constant Bitrate symon_say's Avatar
    Aug 2006
    Dominican Republic
    SONY
    Design [000000000-]90%
    Parts [000-------]30%
    Installation[----------]0%
    Integration[000-------]30%
    Dec 2005
    Freeport, IL.
    Dude, I don't know the voltage output but i'm driving 3 cheap *** Lightning Audio 450 watt amps which is driving 2 subs, 2 2ways and a set of components using the same exact audio card. I have no loudness issues with my setup. Maybe a quality issue, but not loudness..... the only thing I can say is contact creative and ask them what the output voltage is on it.
    Peese
    May 2006
    Belgium
    never said i have problems with my amps, i was just wondering if there was a way to raise the output from my soundcard, so the output would be the same as from a regular headunit...
    Greetz
    Dj NRG
  1. Replies: 11
    Last Post: 09-12-2011, 11:14 PM
  2. HQCT software development
    By Putput in forum Software & Software Development
    Last Post: 06-10-2010, 02:33 AM
  3. Replies: 3
    Last Post: 06-05-2007, 06:10 PM
  4. Problem with Soundblaster external
    By PootsworthIII in forum Car Audio
    Last Post: 06-07-2006, 03:37 PM
  5. Uh oh. No audio from my soundcard..
    By braidy in forum Car Audio
    Last Post: 02-05-2006, 11:59 AM
