Page 4 of 5 FirstFirst 12345 LastLast
Results 31 to 40 of 44
Thread: Who builds their own carputers?
  1. #31
    It's not really that small...No, seriously. judoGTI's Avatar
    Feb 2004
    Florida
    Building you own is the only way to go. Prebuilt carputers most the time are crap.
    '02 GTI
    [Routis '04] [Opus 90W] [160GB Maxtor HD]
    [Lilliput 7" TS] [VIA M10000] [XMPCR]
    [512MB RAM] [Custom housing]
    [Deluo GPS Mouse] [E-MU 0404 Soundcard]
    Progress Meter: [==============|] 99.9%
  2. #32
    Mod - Driveline forum
    ClockWorK's Avatar
    Oct 2003
    Michigan
    Always gotta build your own. Hardware and software.
    This way, if it fails, there's only one person to blame. And if it doesn't fail, there's one person to be proud of.
  3. #33
    Maximum Bitrate americasfuture2's Avatar
    Apr 2007
    Edmond, Ok
    i peiced mine together with available parts.
  4. #34
    Variable Bitrate bambam's Avatar
    Dec 2004
    Upstate New York
    Quote Originally Posted by ClockWorK View Post
    Couldn't have said it any better...totally agree!
    "Imagination is more important than knowledge." -AE
  5. #35
    EL CAMINO's Avatar
    Jul 2005
    upland california us
    agreed, heres my last build, (hardware), and in the process of making the software,
  6. #36
    Jan 2006
    Check the link in my signature. I built my car PC case using two single-DIN radio cases. I bolted them together to create a double-DIN enclosure and then mounted everything inside. Then I mounted the LCD on the front, and installed a 4-channel amplifier under the passenger seat.
    Building yourself is rewarding and you feel a sense of accomplishment. Also, for those of us who regard this as a hobby and not just an upgrade to the car audio system, we'd rather build our own system from scratch because it allows us to make use of our creativity and problem-solving skills on a regular basis which would otherwise not be used if we were simply installed a CD player.
  7. #37
    Mod - iPad Forums RipplingHurst's Avatar
    Dec 2007
    Danville, CA
    This was mine, a drawer on my late M35:
  8. #38
    Jan 2006
    Love the drawer idea! Just skimmed your worklog and I'm very impressed with the way you mounted it in the trunk. Makes it very easy to troubleshoot.
  9. #39
    Dec 2007
    Danville, CA
    YES, it was great for troubleshooting indeed!
  10. #40
    Variable Bitrate mayhembdm666's Avatar
    Mar 2008
    Adelaide, Australia
    I would have to agree with Build Your Own - BYO.
    There are many reasons this works, The main one being customized and tailored for the job. If you use a slot in pre-built device that is made as a one fits all.. Then its going to be restricted and configured to work on a lower level.
    Having built something yourself, You know how much power the thing is needing and taking. You know what sound card is being used and the ratings. You know that the DVD drive has a slight angle mount for when loading your disc's.
    All of these little things matter so much in the larger end picture, Doing all this means cables are run to the length they are needed, Secured at the right places with the right colours and connectors ready to be removed and installed quickly..
    Another thing which i dont know how many people have done, But is something i recommend.. Having a bench plug/socket installed.. This way when you remove the unit(s) from the car. You will be able to place it on the desk. Plug in one single plug and everything is good to go.. This has been one of the issues that allowed me to remove the projects easily and when i want to quickly so i can make a change and put it back in without it taking an hour.
    2004 Holden WL Caprice Auto GENIII
    Base System = Raspberry Pi
    Everything else is pending for now as switched from a Mini-ITX setup
  1. Car audio quality in carputers
    By some_cs_student in forum Car Audio
    Last Post: 01-18-2006, 01:19 PM
  2. carputers? what's that.
    By xtraxmechx in forum General MP3Car Discussion
    Last Post: 06-05-2005, 07:49 PM
  3. pre-built Xenarc carputers any good?
    By ayclens in forum General Hardware Discussion
    Last Post: 07-07-2004, 10:44 AM
  4. Replies: 19
    Last Post: 07-03-2004, 08:39 AM
  5. Summertime performance of carputers!
    By gtboi in forum Newbie
    Last Post: 06-23-2004, 09:25 PM
