+ Reply to Thread
Results 1 to 6 of 6
Thread: Good System with Centrafuse
    Jul 2007
    im going to use centrafuse, umm is a VIA 1.2 GHZ going to do it w/ 1 GB of ram??? Or am i going to need more juice, like go a Micro ATX?
    Maximum Bitrate NiSlo's Avatar
    Nov 2006
    Gold Coast, Australia
    I'm using the M10000 (1ghz) and 512mb of ram and it works flawlessly. A stripped out operating system helps a bit there.
    I installed my carpc into my pet Kangaroo, mate.
    Jul 2007
    what is better the M10000G or the M12000G would either of these be the same as yours?
    Nov 2006
    The M10000 uses a 1.0 ghz CPU while the M12000 uses a 1.2ghz CPU so it's faster than mine. I'm pretty sure there is difference in the mainboards themselves as well (what is included onboard etc).
    Jul 2007
    srry i meant the MII series with the CF card built into the MOBO. Is Basically a 1.0 GHZ CPU will do just fine, which is good to hear. So my next question is the MII 12000G be a 1.2 GHZ CPU and be a good choice?
    Jul 2007
    speaking of Centrafuse... what GPs system do you use, the one it comes with, does that have turn by turn? Also how did you set up voice commands. I had a problem with the SAPII voice software from Windows, and i cant get it to synch with Centrafuse, any help would be greatly appreciated.
+ Reply to Thread
  1. New Release Centrafuse 1.20
    By veetid in forum Centrafuse
    Last Post: 10-10-2007, 08:12 PM
  2. small video clip of my system running centrafuse 1.6
    By shuggyboy in forum Centrafuse
    Last Post: 06-26-2006, 05:10 AM
  3. Ground audio system to battery??
    By eddie in forum Car Audio
    Last Post: 05-30-2006, 03:34 PM
  4. Replies: 1
    Last Post: 03-25-2005, 06:11 PM
  5. Is this a good system
    By mprover in forum General Hardware Discussion
    Last Post: 09-11-2000, 03:20 PM
