Results 1 to 1 of 1
Thread: Need a little help
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    Need a little help
    Hey guys, I need a little help with a wiring relay/transistor. I don't want to use relay so is there any transistor that can do what a SPDT relay can do like the circuit below.
    Basically, it is for my car signal light. I want to make the turn signal light into marker/blinker combination. During the day (no marker light), the signal still flashing (ON-OFF-ON-OFF). During night time, the marker will be on and when using turn signal, it will flash (ONNNNNN-OFF-ON-OFF-ONNNNNN).
    I search like a madman but couldn't find a simple transistor/FET/.... that can do like that. I want a simple device to replace and not a full blow circuit.
    If there is a PNP transistor with normally close and open when apply power to the BASE, it will be perfect.
    Is there such thing exist?
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
