Results 1 to 5 of 5
Thread: "0" on the LPT output when the PC is switching on. how? - closed
    Jul 2007
    Hello.
    I am EPIA-M10000 and using LPT port(I am using data points, point 2,3....).
    When I just switching on my PC on the LPT port appears "1", it remains there during windows loading ....
    For a second it sets to 0 (when the drivers are loading, during windows booting) and again back to 1.
    Is it possible somehow to have 0 on the lpt output when the PC is booting?
    Regards, Alexy
    May 2006
    Belgium
    would it be a problem if it had 0the whole time, except that 1 second? otherwise you could just invert the signal...
    Greetz
    Dj NRG
    Jul 2007
    Closed.
    Jun 2006
    I will tell you
    look you have to make 2 pins 4 switching and connect those 2 pins to IC
    so the IC is like :
    pin 1 = 1 and pin 2 = 1 then out put = 0
    pin 1 = 0 and pin 2 = 0 then out put = 0
    pin 1 = 1 and pin 2 = 0 then out put = 1
    pin 1 = 0and pin 2 = 1 then out put = 1
    so when the car starts all pins should be 1 or 0 and the outout of the IC will be 0
    when the windows start , you have to make a startup exe to do send
    or
    after that it will wooooooooooork
    the IC number is : 4030
    good luck
    [email protected]
    Jul 2007
    sounds good
  1. lillput pc
    By nissan316 in forum Newbie
    Last Post: 06-16-2007, 12:43 AM
  2. For Sale for all you aussies. Complete mp3 car pc
    By Holden__V8 in forum Classified Archive
    Last Post: 04-09-2005, 06:30 AM
  3. Pc output to Lcd
    By Blop in forum LCD/Display
    Last Post: 07-19-2003, 03:23 PM
