Results 1 to 10 of 13
Thread: 3 Way Valet Switch Diagram - Transister Needed?
    Jun 2007
    Oxnard, CA
    Hey guys/girls
    In the process of setting up a valet switch, which is fine and dandy but I'm confused on one part.
    I want to have my computer power up when I unlock the doors with my key fob then remain on once I turn on the car. Along with the traditional valet switch functions.
    What I am unsure of is if I need some kind of transistor in the highlighted area or if this would work as is.
    Name:  3way switch.gif
    If someone could kindly tell me if I'm on the right track or not that would be greatly appreciated.
    Thanks!
    Low Bitrate 95rodeo's Avatar
    Oct 2006
    Auburn ca
    you could get away with a pair of diodes there, to prevent your domelight from backfeeding into your ignition or vice versa. but your 07 civic should have switched ground not switched 12v at the domelight. if you add a relay on that switched ground you can switch the polarity and it sounds like you would be in buisiness
    Jun 2007
    Oxnard, CA
    Thanks I didn't know that it was the negative that was switched.
    So I think I understand the use of the relay (after three edits lol)
    Name:  3way switch 4.gif
    Would it make a difference if I were to use a coil or photo isolated based relay?
    Oct 2006
    Auburn ca
    i would use a standard spdt bosch style automotive relay and the funky little black boxes are diodes. sorry i dont have photoshop so this is a mockup from paint
    Jun 2007
    Oxnard, CA
    no problem as long as it gets the point across ^_^
    Thanks a lot!
    Oct 2006
    Auburn ca
    no prob
    Jun 2007
    Oxnard, CA
    Heres an updated version thats a little clearer for anyone thats interested.
    Name:  3way switch5.gif
    So regarding the -12VDC... where is that coming from exactly if the "switched ground from dome light" would be the negative on the light.
    Oct 2006
    Auburn ca
    it would be the same as the 12v constant wired at the switch
    Jun 2007
    Oxnard, CA
    gotcha, thanks!
    Oct 2006
    Auburn ca
    once again no prob
  1. Capture GPS data at the flip of a switch
    By Mr. Inquisitive in forum GPS
    Last Post: 02-02-2005, 07:06 PM
  2. Wiring Help Needed Please
    By tbird2340 in forum Newbie
    Last Post: 08-31-2004, 01:02 AM
  3. Help needed on switch install for Inverter
    By eazyrog in forum Power Supplies
    Last Post: 07-24-2004, 07:42 AM
  4. Installing On/Off Switch with Opus 90W
    By Judgement in forum Power Supplies
    Last Post: 07-02-2004, 02:43 AM
  5. Help With Extending Laptop Docking Station's Power Button
    By JeffesonM in forum General Hardware Discussion
    Last Post: 04-14-2003, 02:13 AM
