Results 1 to 2 of 2
Thread: iR Repeater Project
    Oct 2006
    San Antonio, TX
    iR Repeater Project
    Has anyone attempted to build something like this
    http://www.bcae1.com/circuits.htm
    It looks pretty simple, by my soldering skills are terrible. I have trouble looking at this diagram and figureing out where the power and ground go to, both look like they are on the fuse, which doesn't make sense to me. Does anyone have a finished picture of one, or a similar design? Would anyone be willing to make one for me for a small fee + parts? Thanks
    Hardware: [-------- ]30%
    Software: [----- ]20%
    Install:[------- ]70%
    2005 Subaru WRX - New 1.83 GHz Mac Mini - OSX/parallels is my front end - K301 InDash monitor
    Nov 2006
    Huntsville, AL
    Hi OUSilver,
    The circuit is fairly simple. D1 is used only for reverse polarity protection. Remove it, as well as the black connection from D1->Fuse and D1->R1. So you are left with +12V->Fuse->R1. The rest of the black is ground. Just don't hook up the power supply backwards.
    Actually, given the very low current draw of all components used, even the fuse is probably overkill. It's obvious that he's designed the circuit to be very robust under adverse conditions (read: idiot-proof), but the diode and fuse are basically overkill.
    In fact, even R1 is overkill, assuming you have a clean 12v source. Besides, 1ohm 1/4Watt resistors aren't exactly common. Anyway, that's what C2 is there for: Noise filtering.
    pb
  1. FS: Lilliput 8" LCD w/ 2 Project Housings
    By migel628 in forum Classified Archive
    Last Post: 09-14-2005, 07:40 PM
  2. The Vectra CarPC / CarPuter Project v2
    By ccsnet in forum Show off your project
    Last Post: 08-29-2005, 06:46 PM
  3. IRMAN v. Cheapo USB IR Receiver....differences?
    By hd54321 in forum Input Devices
    Last Post: 09-14-2004, 02:44 PM
  4. connecting IR receiver to EPIA mobo header
    By chiefsalami in forum Input Devices
    Last Post: 09-02-2004, 08:16 PM
  5. RLion Project Webpage
    By Reactor in forum General MP3Car Discussion
    Last Post: 02-18-2004, 06:43 AM
