Results 1 to 8 of 8
Thread: 2-second power on circuit needed
    Jun 2007
    St. Louis
    this is sort of an odd request maybe, and I don't think it would be very hard, but I have a need of a circuit (most likely involves a relay) that upon detection of the power button on the pc, will close a circuit for 2-3 seconds.
    Basically I have a bluetooth GPS that doesn't auto-power on (but it does auto-off). What I'd like to do is have a circuit that detects when the carpc is turned on, and simulate the button press on the gps receiver for 2-3 seconds to turn it on. The circuit can be located anywhere, and if this is possible I'll be installing small jumper pins connected to the power button on the GPS unit to which I can connect to the circuit easily.
    can anyone help with this? Please
    Mar 2006
    Colorado, but Canadian!
    I think they make adjustable amp anti-thump kits. Basically a 555, a pot, and a relay. You can build one yourself (easy) or buy one (easiest) then use the amp turn on output as your delayed switch for anything. I think that would be the easiest way. And if you decide to build it yourself I am sure it can be done for under a dollar and there are millions of schematics floating around the web.
    1.9in x 2.9in -- 47mm x 73mm
    Jun 2007
    St. Louis
    I never thought about the anti-thump method....that would work...but I would need it to hold the circuit closed for 2-3 seconds otherwise the gps receiver won't power on. maybe an anti-thump with a modification would work....
    thanks, I'll do some searching on that idea
    Low Bitrate ajscomp372's Avatar
    Mar 2006
    Buffalo, NY
    Go to the12volt.com and look in the "special application" relays section. If you combine a few of those circuits, you should have something that will do exactly what you need.
    Maximum Bitrate pRoFiT's Avatar
    Apr 2005
    Fresno, CA
    I would use a simple RC circuit with a relay. The capacitor would have to be big though.
    Um, I guess this is where you put something witty.WITTY
    My Web site, in the design stage. http://home.comcast.net/~cstrachn
    Modified RRSkinEditor http://www.mp3car.com/vbulletin/rr-skins/65723-rrskineditor-bugs-fixes-comments-current-progress-outdated.html
    Jun 2007
    St. Louis
    thanks for the link to the12volt.com... looks like I may be able to put something together that would work judging from what I've looked at. Only problem I'll run into is I don't need to feed +12v from the relay, just need it to simply make a closed circuit for about 2 seconds then release
    What's an "RC circuit"?
    I apologize, my first major was in electronics...but that was over 8 years ago now and I've forgotten most of that since I don't use it much.
    Mar 2006
    RC Circuit = Resistive Capacitive Circuit
    Variable Bitrate afterdigital's Avatar
    Aug 2006
    New Ro, NY
    turning on my power inverter automatically...
    I'd like to know how i can have my power inverter turn on automatically when i turn my car on?
    The inverter itself has an on/off switch. i would like to control this thru the car accessory switch. I'm not sure if i use a relay and how?
    I've visited the12volt.com and read up some but it's over my head...
    any help would be appreciated.....
    CTS 05, Mobile Information Center...
    Atom - 1.8ghz
    2GB Ram
    32GB SSD
    8" TouchScreen
    5.6" Screen (overhead) w/reverse capability
    Finished Project
    Car Hacking
    WorkBlog
    Video
  1. BMW carpc, power addons needed?
    By bimmerpc in forum Power Supplies
    Last Post: 06-17-2006, 10:38 AM
  2. help needed for lillput power off
    By xinyuan in forum LCD/Display
    Last Post: 05-29-2006, 01:22 PM
  3. Power Distribution Block recomendations needed...
    By 0okami in forum Power Supplies
    Last Post: 02-19-2006, 11:09 PM
  4. Power distribution clarifications needed please.
    By umarth in forum Power Supplies
    Last Post: 03-11-2005, 11:44 PM
  5. Electronics people, help me with a custom circuit
    By Greenbuggy in forum Hardware Development
    Last Post: 03-07-2005, 09:53 PM
