yes fusion brain can be used. with the drivers installed, and everything working properly, plugging in a second brain will create a second instance in the device manager. That instance Id you copy from the device manager and use in your skin. You can essentially use as many as you want.
There is a forum for the brain. Its a sub-forum of 'general hardware Discussion'. Much of this information can be found in there with a little mouse work.
http://www.mp3car.com/vbulletin/fusion-brain/
LinkBack URL
About LinkBacks
