Results 1 to 6 of 6
Thread: Pontiac OEM XM Tuner
    Sep 2007
    Raleigh, NC
    I recently bought an 07 Grand Prix to replace my totaled G6. I managed to salvage my carputer from my old car. Currently I am planning the new install. The Grand Prix has the XM Radio Package installed and I would like to take advantage of it. The only problem is that the tuner is not the same as the XM direct tuners.
    The tuner has the same antenna connection (No surprise). The OEM tuner lacks the RCA outputs and the 8-pin mini din connector. Instead the tuner has a 16-pin connector. Only 6 wires run into the wire harness.
    I have determined the pins for power, but i cannot discern the functions of the other pins. Obviously, there has to be right and left channels out since the tuner lacks the rca output. The other wires must be for control.
    Does anyone have any ideas as to where to go from here? Thanks for the help.
    Maximum Bitrate fixerofallthing's Avatar
    May 2005
    Lawrenceville GA
    here is something to start with
    The Car 2005 Scion xB
    The Truck 2004 GMC Canyon
    Sep 2007
    Raleigh, NC
    Thanks, that is a tremendous help. Where did you find that? I have spent all day searching for schematics but with no success.
    May 2005
    Lawrenceville GA
    Quote Originally Posted by Disefyl View Post
    I am a professional technician. It is from a paid service from Mitchell.
    Sep 2007
    Raleigh, NC
    Well, it appears that this project may be more involved than I originally anticipated. I was hoping that the output from the oem tuner would be the same as the xm direct. Unfortunately now to use the com port as I had wanted, the single channel "serial data" will have to be converted to two channel send/receive (If I am wrong, someone please correct me).
    Im a mechanical engineer and slightly out of my element, however talking to some of the EE's here at the office it seems possible. If anyone has any advice, I would be most appreciative.
    Mar 2008
    Out of curiosity, does anybody on this forum with Mitchell access have the pinouts for an 06 Grand Prix radio with the six disc in dash changer? I am bound and determined to not just buy one of the adapters and want to build a complete CAN solution that I can integrate directly into my carpc. I am having the damndest time finding these pinouts though.
  1. HQCT software development
    By Putput in forum Software & Software Development
    Last Post: 06-10-2010, 02:33 AM
  2. Got XM to work, then it took a dump
    By DuDs in forum StreetDeck
    Last Post: 05-06-2006, 05:42 PM
  3. XM Satellite Radio to Unveil XM Advanced Services at 2006 Consumer
    By Will Albers in forum General MP3Car Discussion
    Last Post: 03-27-2006, 08:49 PM
  4. xm and radio tuner at the same time
    By n8scstm in forum Car Audio
    Last Post: 04-02-2005, 12:13 AM
  5. Using an XM direct as an XMPCR
    By dacndar in forum General Hardware Discussion
    Last Post: 10-17-2004, 01:21 AM
