Page 3 of 3 FirstFirst 123
Results 21 to 25 of 25
Thread: Relay switchable USB hub?
  1. #21
    Maximum Bitrate JimmyFitz's Avatar
    Nov 2005
    Austin, Texas
    Quote Originally Posted by BAC5point2 View Post
    Actually, I don't need a 4PDT, so how about these:
    http://www.newark.com/35K3220/electr...HRACK-PT370012
    and
    http://www.newark.com/46F3616/electr...UMFIELD-27E893
    I have a question about the orientation of the pins though.
    I found this
    http://relays.tycoelectronics.com/datasheets/PT.pdf
    For the 3PDT relay.
    Can I assume that pins (13) and (14) are used for the coil, and that I'd wire the USB pins from the head unit to (4), (5), and (6), and then wire the thumb-drive input to (1), (2), and (3) and the iPod input to (7), (8), and (9)? I've never used a dual-throw relay before, only SPST's.
    Thanks!
    Pinout for the first relay part #; Your commons are on 7,8,9. Those go to the head unit. Normally Closed are 1-3, that goes to the default device. Normally open is 4-6, and they go to the alternate device. 13-14 are the coil.
    ~Jimmy
  2. #22
    Feb 2008
    Awesome, thank you!
    Do you know of a better socket than the screw-type? I'd just want something that has leads I can just insert and wire from. That would take up MUCH less space and my whole project would actually fit in a small project box.
  3. #23
    Nov 2005
    Austin, Texas
    Awesome, thank you!
    Just solder the wires on to the relay. Sockets are convenient when putting things together. You don't really need the socket.
    ~Jimmy
  4. #24
    Feb 2008
    I was just thinking for convenience of servicing. The relay won't be taxed too hard, or switched too much, so it'll probably be just fine.
  5. #25
    Feb 2008
    OK, I ordered the relay. $4.24 shipped. I got the Tyco 3PDT one I posted above. I'll just solder right to it. I'll maintain additional length on the USB cables in case I need to replace the relay.
  1. Installing a USB Hub up-front? Read this...
    By hd54321 in forum General Hardware Discussion
    Last Post: 02-09-2007, 11:49 AM
  2. Powered Hub, Lots of USB Devices! Will this work?
    By adamharrisuk in forum General Hardware Discussion
    Last Post: 05-14-2006, 11:00 PM
  3. USB Hub not working after coming out of hibernation
    By volum3rider in forum Input Devices
    Last Post: 09-11-2005, 12:07 PM
  4. usb hub power problem
    By modUlarBeing in forum Power Supplies
    Last Post: 11-21-2004, 06:34 PM
  5. wireless usb kb + mouse + hub idea
    By crippy in forum Input Devices
    Last Post: 10-12-2003, 06:06 PM
