Page 3 of 3 FirstFirst 123
Results 21 to 30 of 30
Thread: 30 Second Off-Delay timer?
  1. #21
    Maximum Bitrate galvitron's Avatar
    Mar 2007
    Socal
    M2-ATX, so DC-DC. My real problem is that the motherboard doesn't have an ATX plug so is not able to signal the M2-ATX to shut off via pins 13 and 14 of the ATX connector.
    2006 Lancer Evolution IX MR In-Dash PC Project - WIP
    Planning:
    [----------] 100%
    Purchasing:
    [----------] 90%
    Installation/Fab/Assembly (Revised v2):
    [----------] 90%
  2. #22
    Maximum Bitrate Injector's Avatar
    Mar 2005
    Rockledge, FL
    Quote Originally Posted by galvitron View Post
    ok so the problem is that the pc won't shut off or the m2-atx won't shut off?
  3. #23
    Mar 2007
    Socal
    M2
    Planning:
    [----------] 100%
    Purchasing:
    [----------] 90%
    [----------] 90%
  4. #24
    Mar 2005
    Rockledge, FL
    ok so wire a relay this way:
    pole 87:
    acc from car
    12v from molex on the pc
    WARNING:
    you NEED to put in diodes on this or you will cause a short
    pole 85:
    Ground
    pole 30:
    12v from the car
    87:
    12v output from the relay, connect to the m2 12v input
    this will make it so that when you turn the key on it'll close the relay and turn on the m2, when you turn the key off acc while shut off but the relay will stay closed because it's still getiing 12v from the molex on the pc, when the pc shutswoff 12v will go away and the relay will open cutting 12v to the m2
  5. #25
    Mar 2005
    Rockledge, FL
    ok i just thought of something, the m2 controls the molex connectors right? if so it will continue to stay on, if the drives shutoff with the pc then you'll be ok, if not instead of a molex to control the signal just use one of the LED connectors at the mobo.
  6. #26
    Mar 2007
    Socal
    I see what you are getting at. But the LED connectors (HDD_LED and PWR_LED) are not 12V right? Aren't they 5V or 3.3V or something? Won't this cause an issue with the 12V coming from ACC?
    Did you look at the timer I bought? I think I can just wire the timer into ACC and the have the timer control the open or closed state of the pin13, pin14 short on the 20pin ATX on the M2. When ACC goes off the timer start and when it is done it opens the connection between those two pins, which tells the M2 that the motherboard has powered down completely and the M2 then shuts off.
    Planning:
    [----------] 100%
    Purchasing:
    [----------] 90%
    [----------] 90%
  7. #27
    Mar 2005
    Rockledge, FL
    that's why the diodes are there, the diode allows power to flow only on one way, as far as the circuit you bought, your theory sounds solid, let me know how it works out.
  8. #28
    Mar 2007
    Socal
    I see. I wish I knew more about this stuff. I got a D in electrical engineering at the Uni (crappy teacher).
    I have a relay and diodes at home so I will give your idea a shot tonight as the timer hasn't arrived yet.
    Thanks for all the help.
    Planning:
    [----------] 100%
    Purchasing:
    [----------] 90%
    [----------] 90%
  9. #29
    Newbie rybitski's Avatar
    Apr 2008
    Virginia
    For future reference a great (and cheap) place to buy electronic components from is futurlec.com and shipping only takes about a week. I have placed many orders with them with no problems.
  10. #30
    Mar 2007
    Socal
    Thanks for the tip. I got my timer today so I will start fiddling tonight.
    Planning:
    [----------] 100%
    Purchasing:
    [----------] 90%
    [----------] 90%
  1. 30 Min Off Delay, M2-ATX?
    By Simon123 in forum Power Supplies
    Last Post: 11-17-2010, 03:26 PM
  2. GPS Power On Delay
    By sevin7 in forum GPS
    Last Post: 02-20-2008, 09:11 AM
  3. Replies: 19
    Last Post: 07-27-2006, 04:44 AM
  4. Speaker Popping Noise (delay circuit options?), Line Drivers to boost volume which 1?
    By SuprchargdMazda in forum General Hardware Discussion
    Last Post: 05-26-2006, 08:57 PM
