Results 1 to 6 of 6
Thread: USB plug
    Mar 2007
    USB plug
    I stumbled accross this and though it was cool.
    http://www.maplin.co.uk/Module.aspx?...C=SO&U=strat15
    Low Bitrate MOnline's Avatar
    Apr 2007
    Holland, Poeldijk (Near The Hague)
    Hmm tnx for sharing dave was looking for something like this .
    With kind regards,
    MOnline
    Mar 2007
    welcome
    Jul 2002
    In the US, Mouser carries those. They're made by Neutrik. I just got a couple for use in my car but haven't installed them yet so I can't report on how well they work. The quality looks decent though.
    They're a lower-cost solution than the mp3Car connector, but not marine grade. Only time will tell if these stand up to use in my car. You'll need to provide your own cable to the back of the connector. They have a USB B jack on the back and you can reverse the insert if you want to have that in front according to the mfg. data. That extra connection on the back may make it a bit less reliable than a hardwired outlet, but the cost difference is significant. I thought I'd just put a piece of heat-shrink over the back connection/cable to make sure it stays in place and to keep any dust out.
    There is a plastic cover you can get to keep dust or whatever out when not in use. I don't know how long the cover's plastic hinges will last, but it isn't very expensive and shouldn't be too hard to replace. There is an RJ-45 version as well as other audio type connectors in the same basic style.
    They also come in black. Mouser didn't have them in stock when I ordered, but the black plastic cover hides the plated body anyway when not in use if you don't want the shiny connector.
    May 2008
    I ordered on of those off ebay in black. It came yesterday. Im going to mount it in one of the cig lighter holes.
    Aug 2007
    New Orleans, LA
    Those connectors are very handy in the live and studio production business where you have computers racked. It should work just as well in the vehicle environment, considering that they were designed to have the living ***** beat out of them. I was thinking about using one of the Netrik RJ-45s and I might use a USB or two in my truck.
    Crawdaddy
    1991 Chevy Suburban 1500 w/SBC 350
    2005 Saturn ION 2 sedan
    Suburban Worklog
    "A local New Orleans man says his socks are finally dry..." -Tom Tucker, Family Guy
  1. Ultimate USB, Firewire, External Soundcard List
    By durwood in forum Car Audio FAQ
    Last Post: 12-30-2009, 06:15 PM
  2. Ground loop with an external USB card?? Help! (LONG)
    By vettejock99 in forum Car Audio
    Last Post: 02-05-2006, 11:20 AM
  3. Replies: 8
    Last Post: 12-11-2005, 03:50 AM
  4. usb plug defective?
    By Frankino in forum LCD/Display
    Last Post: 11-23-2004, 04:08 AM
  5. Replies: 4
    Last Post: 04-06-2004, 10:52 AM
