Results 1 to 9 of 9
Thread: 12v to 5v 5A Power Supply
    May 2008
    Hello guys,
    I looked a lot of projects, but this is the best, because with this, we can
    provide clean 5v power with 5A.
    I just made the Circuit Board, and mounted in my Honda Jazz to
    supply 3 USB hubs.
    The heart of this project is the LM338k Regulator, with a BIG Heatsink,
    this will get hot quickly... :-)
    After you place all in board, u just need to adjust the resistor, to get
    the 5v in output.
    C1 1 14000uF or 10000uf 40 VDC Electrolytic Capacitor
    C2 1 100uF 50Vdc Electrolytic Capacitor
    C3 1 0.1uF Disc Capacitor
    C4 1 0.01uF Disc Capacitor
    R1 1 5K Pot
    R2 1 240 Ohm 1/4 W Resistor
    U1 1 LM338K 1.2 to 30 Volt 5 Amp Regulator
    This is the link for the original project...
    ( I removed everything before the C1, because we have 12v DC)
    http://www.aaroncake.net/Circuits/supply.asp
    Low Bitrate Beehphy's Avatar
    Apr 2007
    The LM338 is a linear regulator. About 60% of the power in a 12 to 5 volt linear regulator gets burnt up as heat. To deliver 50W to the load 65W is burnt as heat.
    Also, this design doesn't have a disable. It never turns off. Unless you have a relay controlling power to the circuit, your battery is toast! Running off your car's battery without the eingine running would drain it really quickly.
    I linear regulator is very stable and free of power line noise, but it is just not worth the waste.
    If you need BIG power to run your USB system, and want to do it with style and grace just follow the link in my sig. 5V@10A, 93% efficient, USB Sync'd, 300 kHz switch freq, and professionaly built.
    Raw Wave Rob Withey's Avatar
    Apr 2000
    Bedfordshire, UK
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by Rob Withey View Post
    Ooh, I like that chip... And 85%+ efficient for high current 5v out. Never even knew it existed. Good find!
    1.9in x 2.9in -- 47mm x 73mm
    Apr 2007
    $36.60 on digikey.com (Link)
    Still needs a little work to become an installable piece, but this will let people with minimal electronics knowlege create a 5V switcher PS for their carpc's in an afternoon.
    Oct 2008
    lm7805
    Another voltage regulator you could use is the lm7805. Its cheap and if voltage between 5-20V is applied the output voltage is a constant 5V.
    Mar 2006
    Quote Originally Posted by Kishon View Post
    Maximum power draw is less than the maximum draw on a standard USB hub, and definately less than 5A.
    Also it is not very stable over vast ranges of temperature.
    I love and use them all the time, they even appear on the FB.
    Oct 2008
    7805c
    Point taken regarding the temp. I don't know which type you are using. I have installed one of these..(below). they seem to handle up to 1.5A and you can add a heatsink.
    Oct 2008
    7805c
    forgot the attachment.LOL
  1. Replies: 115
    Last Post: 03-05-2011, 04:54 AM
  2. Getting 5v AND 12v from POL DC-DC Smart Power Supply
    By XxAndyxX in forum General Hardware Discussion
    Last Post: 06-19-2007, 12:09 PM
  3. amd athlon 1.3 ghz-- where does it get it's power from, 12v or 5v?
    By scott_fx in forum General Hardware Discussion
    Last Post: 02-22-2006, 08:53 PM
  4. del
    By hanzacra in forum Classified Archive
    Last Post: 08-07-2005, 11:32 PM
  5. Inexpensive DC-DC power supply for 12V only?
    By P4_2.66GHz in forum Power Supplies
    Last Post: 11-20-2004, 10:17 PM
