Results 1 to 10 of 10
Thread: tweeters made into a boombox
    May 2008
    Hey all,
    I have just installed some new splits into my car, which means I have taken the stock ones out. I have some tweeters and woofers, and I was thinking of usuing the tweeters tomake some portable speakers out of. I was thinking of making a little box for them, and then wiring a stereo jack so that I can plug them into the headphone jack of anthing and they'll play sound. The only thing is, will I need some sort of amplifying circuit to make the tweeters run? If so, how can I go about making one (that isn't too expensive, and as basic as possible).
    If it helps, the tweeters came out of a VX Commodore Lumina (if you guys know what kinda car that is?), and the tweeters are approx 5 cm in diameter (or 2 inches).
    You might ask why I wanna do this. The answer is, because I can , well actually I can't just yet, but once I get some info from people, then I will be able too haha :P.
    Jun 2006
    Calgary, Alberta
    Blog Entries
    1
    Using just a tweeter is going to sound pretty bad. But if you still want to go for it, here is a good site I use to find circuits (search for audio amp):
    http://www.discovercircuits.com
    Variable Bitrate eric_barcus's Avatar
    Mar 2007
    May 2008
    hey cheers for the reply nobb. Well I have the woofers that I could use... but then they wont be so portable haha. I'm just playing around anyways, seeing what I can do earning along the way . I will have a look see at that website right now .
    Low Bitrate Rowan's Avatar
    Aug 2005
    Melbourne, Australia
    I made a reallll boom box, that has 2x 12" subwoofers, a 4-chan amp, and a oddessey battery in a custom fab MDF box that we took around everywhere, from BBQ's, camping, parties.. :P
    2x 6x9" speakers plugged into the back and were on 10m long leads.
    Holden VY Calais 5.7lt LS1 V8
    Computer:
    MB896 Pentium M Mini-ITX Motherboard, Intel Pentium M 750 1.86 GHz, 1Gb DDR2 Ram, 250GiB SATA, Xenarc 800TSV 8" VGA Monitor with touchscreen, GPS/Cellular/PCS/WiFi antenna, Bluetooth GPS, etc ,etc
    Mar 2007
    ^ROWEN^ you got pics of the boom box?
    May 2008
    yeah Rowan, let's see some pics!!
    Low Bitrate Beehphy's Avatar
    Apr 2007
    Quote Originally Posted by b1b2b3 View Post
    dito.
    Aug 2005
    I'll try find some on the weekend, the amp melted (well, started smoking so I turned it off, opened it up later to find a bulk of the mosfets had been destroyed) at the end of 2006, and since I haven't had the need to use it much recently I haven't bothered to fix it up, so it sits in the garage gathering dust. During it's 'prime' however it was pretty cool, I soldered SMD led's to the inside of the grills protecting the subs and hooked them up to the amp, so they went to the beat of the music. I have a few pics of that too which i'll dig up and post later on.
    Computer:
    May 2008
    Yeah rowan if you could post a few pics of how you did the SMD LED's, I am looking at doing something like this inside my car, and am looking for examples to work off of . Thanks.
  1. Neon Boombox users guide
    By NeonDev in forum Neon Boombox
    Last Post: 09-09-2008, 06:18 PM
  2. Mod TM-868 with Car tweeters?
    By H_C in forum Car Audio
    Last Post: 05-21-2007, 10:26 PM
  3. Replies: 15
    Last Post: 09-07-2004, 11:07 AM
  4. I made some more things for my carputer
    By turbochris in forum General Hardware Discussion
    Last Post: 07-12-2004, 08:22 PM
  5. Replies: 4
    Last Post: 04-10-2001, 01:10 AM
