Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: Single board computers
  1. #11
    Newbie nemoid's Avatar
    Jan 2008
    914.ny
    You can go with a Pico board...
  2. #12
    Jun 2008
    Quote Originally Posted by nemoid View Post
    Interesting you say that. My project started off life by looking at attaching this device to an LCD display. How does this chipset compare to the T7500 with GM965? I'm guessing it pulls a lot less power but is a lot less powerful.
    The lack of support for MacOS is an issue (not that we would run it illegally or anything). It is also quite deep again. This seems to be a big issue with the smaller boards. I can go up to 5.25" if necessary but no thicker than 25mm. I've looked at the nano boards too but would prefer something that is at least as powerful as the T7500.
  3. #13
    Maximum Bitrate galvitron's Avatar
    Mar 2007
    Socal
    LS-372 is only slightly larger than the Pico board and is vastly beyond it in terms of horsepower.
    I have the T7500 with mine and it in no way takes 70 watts. more like 20 or less at idle and 40 or 50 at load. The T7X00 series CPUs only consume 35W max and have a throttle-down feature and RAM should be just a couple of watts with SO-DIMMs. The northbridge and other MB stuff are from the GME965, a laptop chipset, so they shouldn't consume much, probably 10W max (just a guess). You could probably reach close to 70W if you ran every single device at full load (extremely unlikely).
    The northbridge heatsink is very tall, but if you have an alternate means of cooling and know what you are doing you should be fine in removing it. The CPU just has a small screw-on fan that can be replaced.
    2006 Lancer Evolution IX MR In-Dash PC Project - WIP
    Planning:
    [----------] 100%
    Purchasing:
    [----------] 90%
    Installation/Fab/Assembly (Revised v2):
    [----------] 90%
  4. #14
    Jun 2008
    Thanks for that. I can cope with 40-50 load and 20 on idle. I guess it's time to bite the bullet and actually order one.
  5. #15
    Mar 2007
    Socal
    Cool. It's really a nice board (from my experience).
    Planning:
    [----------] 100%
    Purchasing:
    [----------] 90%
    [----------] 90%
  1. which itx board should a take?
    By frankman in forum Newbie
    Last Post: 12-12-2005, 11:52 AM
  2. How is this motherboard? Intel board inside..
    By sspiro in forum General Hardware Discussion
    Last Post: 01-16-2005, 02:16 PM
  3. Sweet board for a CarPC
    By fearthepenguin in forum General Hardware Discussion
    Last Post: 11-15-2004, 05:08 AM
  4. Single Board PC for 130 ($180 ish)
    By nevb in forum General Hardware Discussion
    Last Post: 07-26-2001, 06:25 PM
