Results 1 to 10 of 15
Thread: Single board computers
    May 2005
    Hey guys,
    Other than Advantech, who makes 3.5" single board computers? I have an Advantech Celeron 600 SBC and would like to upgrade to something with more power, but their CPU selections aren't all that great.
    Thanks!
    Nov 2007
    yes, try avalue.com.tw. i am installing a 3.5" board (ECM CX-700). VIA Eden CPU 1GHz which is quite good for my application. they also have other product lines supporting intel
    i get the board and bought 512MB DDR2, 120 GB sata laptop HDD, IDE laptop CD/DVD RW drive, touch screen Exaudio 16:9
    btw, i personally found 3.5" pc board one of the best options for carpc because mostly of its size, low power consumption, quietness (fanless CPU)
    Feb 2006
    Melbourne, Australia
    Hello,
    You can have look at the Commell LV-372 - a very decent platform, allowing you to use any of the new Mobile Socket-P Intel Core2 Duo cpus (aka Santa-Rosa)
    F6 Tornado Project Log ; HP Blackbird Watercooled Server
    Beta Tester for Centrafuse and 3dConnexion (No business affiliation with either)
    Maximum Bitrate galvitron's Avatar
    Mar 2007
    Socal
    ^^ Do you mean LS-372? I think the LV are bigger than 3.5, right?
    Commell makes a ton of them. You might also check Global American, Inc. and bwi to purchase these types of boards.
    2006 Lancer Evolution IX MR In-Dash PC Project - WIP
    Planning:
    [----------] 100%
    Purchasing:
    [----------] 90%
    Installation/Fab/Assembly (Revised v2):
    [----------] 90%
    Jun 2008
    I'm just designing a project around a 5.25" form factor and these 3.5" boards give me a lot of options. However, it appears the manufacturers aren't so concerned about the depth o these devices and rarely give any mechanical design details.
    I see from project posts that you both have an LS-372 and this appears to be an idea motherboard for my project. Do you know the board depth (with and without heat spreader, sink or fans?
    Any help would be much appreciated.
    Edited to change LV to LS.
    Mar 2007
    Socal
    Are you replying to me? I have the LS-372, not the LV-372.
    I only have dimensions without the heatsink/fans. But, you can't really take them off unless you have some VERY effective alternate solution.
    W: 5.75" x D: 4.0" x H: ? (W: 146 mm x D: 102 mm x H: 16.56 mm)
    You should be able to find the specs in their downloadable manuals.
    Planning:
    [----------] 100%
    Purchasing:
    [----------] 90%
    [----------] 90%
    May 2005
    Hmm.. that LS372 looks like it might work for me..
    I am fairly limited by the board layout as it has to fit inside the case I designed and had made:
    As you can see I am somewhat constrained by the position of the VGA connector...
    Mar 2007
    Socal
    Well the VGA on the LS-372 is in about the same position...
    There are quite a few connectors on the back-panel of the LS-372 so if you want to use them you would have to cut the case.
    You could use the 4 USB headers on the top of the board for USB, and the audio and com ports are coming off the top, not the back-panel, via headers.
    There is another thread (I think started by Mr_Bean above) that had a cool alternative case you could use...
    Planning:
    [----------] 100%
    Purchasing:
    [----------] 90%
    [----------] 90%
    Feb 2006
    I meant LS-372, soz guys
    Have a looky here, this was what Galvitron was referring to.
    Jun 2008
    Quote Originally Posted by galvitron View Post
    @Galvitron, Sorry, yes I should have refered to you, or mrbean_phillip, in my original post as I noticed you had both built projects around the LS-372.
    I'm trying to build a project that has a depth limitation and most of the manufacturers don't appear to worry too much about depth. The figures you provided above are in the LS-372 manual but the depth figure only measures the circuit board to top of edge connector depth. There is not reference to the clearance required on the solder side (I noticed that the compact flash socket is on that side of the board). In addition, the heat sink on the GM965 looks pretty high in the pictures of your G5 project (again, no mention of this mechanical specification by the manufacturers).
    If the compact flash doesn't add too much depth (or I can easily remove it as I don't need it) then I'll happily remove the heat sink for both the GM965 and Processor. I intend to provide heat transfer using a heat spreader, pipes and a fan not mounted directly on the processor.
    I'm also now worried about the power consumption of this device. Global American mention a typical power consumption of 79W with the T7700. I was going to use the T7500 but that power consumption seems very high. The other 965 board they offer appears to have half the power consumption (a AZURE Mercury 965?) but no DVI or HDTV output. If the LS-372 doesn't pull that much power unless using the DVI or HDMI then I'll be happy.
    Again, any help greatly appreciated and sorry if I'm hijacking this thread. Happy to move this dicussion elsewhere.
  1. which itx board should a take?
    By frankman in forum Newbie
    Last Post: 12-12-2005, 11:52 AM
  2. How is this motherboard? Intel board inside..
    By sspiro in forum General Hardware Discussion
    Last Post: 01-16-2005, 02:16 PM
  3. Sweet board for a CarPC
    By fearthepenguin in forum General Hardware Discussion
    Last Post: 11-15-2004, 05:08 AM
  4. Single Board PC for 130 ($180 ish)
    By nevb in forum General Hardware Discussion
    Last Post: 07-26-2001, 06:25 PM
