Results 11 to 20 of 23
Thread: Alarm Pager (delay time)?
  1. #11
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    T1 is the TIME frame of the circuit. If you want a 10 to 11 sec delay then you need a CAPACITOR (C) of 100 micro farad and a RESISTOR (Ra) of 100k. The other capacitor stays at 0.01 micro farad. If you apply power to the circuit (+ -), the output of the 555 pin number 3 is off untill T1 expires, then the output turns on and stays on untill you remove power (+ -)
  2. #12
    Jun 2008
    Hi :-)
    Thanks again for the help
    What "other capacitor stays at 0.01 micro farad" ?
    and what do you mean by "the output of the 555 pin number 3 is off untill T1 expires" . I don't know what a T1 is...lol?
    I've managed to find some 100uf caps on an old motherboard but the only resistors I have are 150uf Will these make much of a difference?
    Also can someone please help me with the things I have marked out in the pic.
    Thanks again everyone I really appreciate the help ;-)
  3. #13
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    If you don't understand the instructions or what component is what, you better off not building any circuits.
  4. #14
    Jun 2008
    Its the first time ive come across a 555 timer so im trying to learn how they work
    Im sure you was the same when you started off.
    Anyway if anyone can help me with the above I really would appreciate it
    Thanks anyway ;-)
  5. #15
    May 2006
    Calgary, Alberta
    People are ignoring me again.
    Ampie Case
    256 MB DDR2 PC5400
    Xenarc 700TSV - VGA Monitor
    Intel D945GCLF Motherboard
    M2-ATX-HV
    2005 Honda Civic
  6. #16
    Jun 2008
    Quote Originally Posted by Maheriano View Post
    Sorry mate I didn't mean to ignore you :-(
    I think using an old prepay mobile phone is the better route as it can also be traced and can be easily hidden in the car ;-)
  7. #17
    Jun 2008
    After a bit more reading I think I know what im doing but can someone please look at my new edited diagram (attached) and let me know if everything is correct
    If everything is correct I only have two more questions.
    1. Can the 0.01uf capacitor be substituted as im having a hard time finding them?
    2. Does the voltage on the capacitors make a big difference as some are 16v and others are 25v...etc?
    Again thanks for all the help your giving me
  8. #18
    Jun 2008
    Anyone
  9. #19
    Vendor - Qube colin's Avatar
    Dec 2006
    You should not need a diode to make a simple timer...
    If you're still confused, google for asynchronous 555 timer or something. If you want a timer that keeps going constantly, google free running 555 or something along those lines...
  10. #20
    Sep 2006
    SK
    Quote Originally Posted by colin View Post
    I think you mean astable 555, but still, he's using it as monostable circuit - not a timer that keeps going constantly.
    I haven't examined the circuit but I'm going to guess the diode is necessary (or at least recommended) otherwise it wouldn't be there.
  1. GPS time delay after Standby
    By Mazda6gp in forum GPS
    Last Post: 05-21-2008, 12:00 PM
  2. Replies: 2
    Last Post: 01-31-2008, 03:15 AM
  3. Survey: Startup times and methods
    By gnomad in forum General MP3Car Discussion
    Last Post: 01-02-2007, 12:55 PM
  4. Replies: 3
    Last Post: 11-04-2004, 11:11 AM
