+ Reply to Thread
Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: Alarm Pager (delay time)?
    Jun 2008
    Exclamation Alarm Pager (delay time)?
    Im thinking of wiring up an old mobile phone to my car alarms siren so when the alarm is triggered it uses the speed dial feature of the phone and phones me.
    There was someone on the net that says he will mod any mobile phone to do this but he wanted about £100 + plus a phone.
    I've managed to get it going using a 5 pin relay the only problem im having now is that I tried wiring it up to the siren so that when the siren goes of it activates the relay and calls me the only problem with that is that every time you turn on/off the alarm the siren chirps and the thing phones me up...lol
    im starting to think ill need to make a time delay circuit so it doesn't kick in until the alarm has been running for a couple of seconds.
    I've read that its possible to wire a resistor to a capacitor and then wiring that to the relay so that it takes a few seconds for the for the cap to charge before triggering the relay but there wasn't any mention of what resistor or cap that is needed :-(
    Any help would be greatly appreciated ;-)
    Jun 2008
    Exclamation
    Anyone
    Variable Bitrate tigergibb's Avatar
    Nov 2006
    Snellville, GA
    555 timer.. google it
    2003 Nissan Xterra Worklog
    Total amount spent so far: $1196.64
    You will probably spend AT LEAST 2x what you initially budget for your CarPC Project!
    2003 Nissan Xterra - Modifications
    Jun 2008
    Thanks for the reply
    I was going to do a 555 circuit but when I went to buy them there was three different types a NE555N a NE555D and a LM555 and I wasn't sure what to buy. Also I couldn't find a diagram for the pins let alone wad caps and resistors I would need, then I come across an old site where someone said that they managed to get a delay using only the caps and resistors but again they didn't say what ones where needed
    Sep 2006
    SK
    Quote Originally Posted by abbbe View Post
    The extra letters identify minor details like manufacturer, package type, temperature range, etc. It would be best to get one as a DIP package as they are easiest to prototype with. It would also be a good idea get one with a wide temperature range. So the NE555N or SA555 or LM555CN would work.
    Jun 2008
    Thanks for the info
    I've ordered some 555 timers but I cant find a diagram on how to wire it up
    All I need is a delay of about 10 seconds (can be a bit more or less) from a 12v source to the relay.
    There's loads of diagrams on the net but none of them are for the simple circuit I need
    Can anyone please point me in the right direction
    May 2006
    Calgary, Alberta
    Wouldn't it be easier just to use the web to send yourself a text? A phone call will be pointless, you're just going to look at the number and hang up anyway right? Plus with the SMS, you don't need to use another phone.
    Ampie Case
    256 MB DDR2 PC5400
    Xenarc 700TSV - VGA Monitor
    Intel D945GCLF Motherboard
    M2-ATX-HV
    2005 Honda Civic
    Vendor - Qube colin's Avatar
    Dec 2006
    Ahhh finally the electronics comes in handy.
    You can make a very unstable timer using a simple resistor and cap circuit. The cap charges and then discharges through the resistor, which takes a determined amount of time. Problem with this is heat variation... changes everything. Your timing isnt too specific though so this should work just fine for what you want.
    555 is overkill for this situation because of the extras required.
    http://www.elxevilgenius.net/08Prjects/processr/RCI.htm
    http://robots.open.ac.uk/ibotz/RCcircuits/
    http://hop.concord.org/amu/amu.mess.act3.html
    Sep 2006
    SK
    Jun 2008
    Thanks for ALL the replies
    Ill stick with the 555 for now seeing as I already bought them.
    This diagram seems to be the best one ive seen: http://clarkson-uk.com/555-timer/operation/frames3.html but there are a few things im not sure about like what does T1, RA and C mean?
    Also there are a few things on the diagram I don't understand so ive edited it slightly and attached it below.
    Thanks again everyone
+ Reply to Thread
  1. GPS time delay after Standby
    By Mazda6gp in forum GPS
    Last Post: 05-21-2008, 12:00 PM
  2. Replies: 2
    Last Post: 01-31-2008, 03:15 AM
  3. Survey: Startup times and methods
    By gnomad in forum General MP3Car Discussion
    Last Post: 01-02-2007, 12:55 PM
  4. Replies: 3
    Last Post: 11-04-2004, 11:11 AM
