Results 1 to 10 of 16
Thread: How do I get an analog out to control a blower motor?
    Apr 2008
    Baghdad, Iraq/Fort Bragg, NC/Saginaw, MI
    I've been reading data sheets for weeks now... I can get an analog out, at 1ma, but how to I "amplify" that to control a blower motor? I don't even really know how much amperage the motor takes... right now, the "stock" system uses a resistor box; and I'd prefer use a pic, to control it on a scalar level.
    Anyone have any more information other than "google op-amps"? lol
    I'm not really an electronics engineer, but I play one on TV. Seriously... I have a good grasp on how most things work, but without having the stuff infront of me, I can't really make sence of half of the numbers in the datasheets.
    peace
    Mike
    EDIT1: btw, what I'm looking at now, is the IRFP250NPBF http://www.irf.com/product-info/data...a/irfp250n.pdf ... it "seems" like it would work. but again, I'm no electronics engineer. According to the Datasheet, it says that the source drain peaks at 1ma, and the emitter constant drain can be 30A, with a peak of 120A...
    FLAC Chairboy's Avatar
    Jan 2004
    Easy plug & play answer: Get a serial servo controller and use it to run an RC speed control. Those are what electric RC cars and trucks use to power their drive motors. $20-$30 for the serial servo interface, and the same maybe for speed control.
    Chrysler 300 - Fabricating
    http://hallert.net/
    Apr 2008
    Not sure if those RC speed controllers can handle 30 amps..
    for (HIGH) speed, the blower runs P=220W, V=12v, R=0.65ohms, I=18.33A
    Jan 2004
    Plenty of them can handle that load. I googles "30amp speed control 12v" and found lots of matches. Just let your browser do the walking.
    http://hallert.net/
    Jan 2004
    You know.... It might be cheaper to get, instead of a speed controller, a servo. Attach it to the old controls behind the dash and make it "turn" the knob.
    http://hallert.net/
    Oct 2006
    Las Vegas
    Quote Originally Posted by Chairboy View Post
    That's a viable answer, but I know it wasn't your first choice. It's a bit of a weak link, to have an electromechanical interface in the middle there.
    If you have a low amp 0-12V signal (or even 0-5V), you could use a power transistor (commonly found in Hondas, comes with a big heatsink, and doesn't require PWM input). Heatsink should go in airstream, just like a blower resistor.
    FLAC WuNgUn's Avatar
    Sep 2007
    This is what I've been thinking about using...
    http://www.hobbyengineering.com/H2338.html
    But I'm not sure how I'd interface it with the PC just yet.
    Jan 2004
    The HB-25 can't be controlled by a servo interface out of the box, unfortunately. It needs 5 ms delays between pulses and only expects to receive instruction when there's a change, instead of a constant PWM stream like RC servo interfaces provide. You could use some of Parallax's sample code to rough together a control for this through your analog output, but it'd be a little work.
    http://hallert.net/
    cheap custom title JC-S60's Avatar
    Mar 2004
    Ghent - Belgium
    And using an electronic (solid state) speed controller for RC cars/boats? That would eliminate the mechanical part and still listen to servo controls...
    Good luck!
    Sep 2007
    Quote Originally Posted by JC-S60 View Post
    Good luck!
    Now why didn't I think of that!?
    They don't seem rugged enough to handle the current though...probably because they spend most the the time at full power?
  1. Ultimate USB, Firewire, External Soundcard List
    By durwood in forum Car Audio FAQ
    Last Post: 12-30-2009, 06:15 PM
  2. Fusion Brain Analog Accuracy and Error Detection
    By DJiK in forum Fusion Brain
    Last Post: 06-08-2008, 11:50 AM
  3. Need wiring help for 2005 Grand Prix.
    By derekmac in forum Car Audio
    Last Post: 09-21-2007, 10:42 PM
  4. Replies: 3
    Last Post: 05-26-2004, 05:08 AM
  5. Replies: 22
    Last Post: 08-13-2001, 02:42 PM
