Hello, here the greek version
Looking good Dejan
My carpc worklog
Robby can you write post for this config tool like you are do for TPMS Doctor that we can see when you update it and what is new?
Bye, _Dejan_
_______________________________________
Car installation 95% [■■■■■■■■■■■■■■■■■■■■]
Current project: Parking sensor USB interface
There is this tread with the version tracker and all the languages already added.
Also, a standalone application for testing the device can be downloaded here.
Greek language added!
I may be misunderstanding, but how come there isn't a small little beeper on the PCB like this ? or at least the holes to be able to solder one on if you want it ?
P4 2.8 HT, 512Mb Ram, 60Gb 2.5 HD, M4-ATX, SB Audigy2, BU353, Lilliput TS,Soundgraph Imon VFD,SONY Optiarc dvd Burner,RideRunner, iGo8, Custom Freedom 2.1
The BMW E36's have a gong under the drivers dash, which is designed to be used with a PDC, so 'we' can just run wires to this
There is a connection on Robbys board to run to a buzzer, bong or whatever sound device.
No need for a buzzer or gong. There is a Label on the screen which shows you the distance. Mine announces the distance in feet every sec. when you back up.
